impedance matching and mic electret ..#2
simonsmart99
Joined Jul 8, 2023
I would be very grateful if you could provide me with an impedance matching circuit which would convert a “2k2 ohm Electret microphone into a standard low impedance mic input (50mv – 2v at 100 ohm).
Many thanks in anticipation..
Kind regards
Simon
BobTPH
Joined Jun 5, 2013
11,556
You seem to have a misconception about impedance matching. Matching the impedance of the mic will reduce the output voltage by a factor of two. Connecting it to a high input impedance amp will pass the entire output voltage giving you twice the signal of the impedance matched one.
simonsmart99
Joined Jul 8, 2023
Hi BobTPH
Yes, it is most likely I am confused, hence my post. To clarify, I am trying to connect an avionics headset which has an electret 2,2k ohm impedance microphone to an airband radio which expects a standard low impedance mic. I have attached the transciever input specification for clarity.
Kind regards
Simon
