Hi everyone,
The transmitter output path is RFpin → Choke → DC-Block → Matching Network (PI/T) → 50 Ω antenna. Because the datasheet doesn’t pin down the pin impedance, I probed it directly: Zin (RFpin) ≈ 6.6 – j108.5 Ω (|X|/R ≈ 16.4). I now want to confirm the loaded Q / -3 dB bandwidth of the full chain by sweeping S21.
If I measure S21 with the VNA’s usual 50 Ω ports and take Q = f₀ ⁄ (f₂ – f₁) at the -3 dB points, does the mismatch on the source side (6.6 Ω vs 50 Ω) simply fold into that result, or should I de-embed the 6.6 – j108.5 Ω first (e.g., with a broadband matching pad or offline renormalization)? Likewise, for isolating the contribution of each PI/T cell, is it worth breaking the chain and inserting 50 Ω fixtures, or is post-processing the full S-matrix standard practice?
Any proven technique or reference that keeps the setup simple while still giving a trustworthy Q figure would be a big help—thanks!
— Kafei
— Kafei
