Measuring noise floor
rpschultz
Joined Nov 23, 2022
851
Hi
I have designed an acoustic guitar preamp. It has 1 NE5532 and 3 TL074s running at +/-15vdc.
Many good preamps list their noise floor, like this:
I have a good scope (Siglent SDS804x hd) and a AWG. Could I replicate some of those type of tests? I also have some OPA4134s I thought about trying.
here’s a picture of me looking at bode plots of it, one of the knobs is a notch filter
schmitt trigger
Joined Jul 12, 2010
2,252
I don’t think that your setup can achieve a 128dB range.
There’s a reason why audio analyzer equipment like the Audio Precision is expensive, and it is because of the wide dynamic range.
Additionally you must provide a bandpass circuit function which should not introduce noise of its own.
I may be wrong, I am not familiar with your scope, but perhaps your best bet is to lease an analyzer equipment.
35,210
0 dBm is 1 mW into 50 Ω, that is 224 mV.
-120 dBm is 0.001 pW or 224 nV, that is 0.2 μV.
Can your test equipment measure less than 1 μV?
rpschultz
Joined Nov 23, 2022
851
No my scope only does 0.5 mV.
are there simpler tests I could perform to compare it running TL072s vs OPA4134s?
0ri0n
Joined Jan 7, 2025
193
Most of the tests could work, maybe even the noise test. You can certainly try by switching to the frequency domain. The scope is only a 12-bit model but the huge 2Mpoint FFT capability, >10Mpoints aquisition, time domain/FFT averaging, windowing and oversampling adds a lot of processing gain. On my 12-bit Rigol, depending on settings, I can reach a -140dBV noise floor and have a usable dynamic range of 120dB at audio. You obviously can't compare a 12-Bit scope to a decent 24-bit ADC but a lot of audio tests can be done with it.
schmitt trigger
Joined Jul 12, 2010
2,252
Returning to your project...it looks really beautiful!
And I expect that it will sound as good as it looks
And a cautionary tale: Texas has decided to re-design the venerable TL074 and replacing the JFET input stage with a CMOS input stage. Renamed it the TL074H. Those devices offer several improvements, one of them definitely NOT being noise. In particular the 1/f noise has been reported to be significantly worse.
rpschultz
Joined Nov 23, 2022
851
TL074 is a JFET, ne5532 is bipolar. The new TL074H is CMOS. I don’t understand the difference.
for audio at relatively low frequencies (<20khz), requires low or very low noise and high impedance. Current draw isn’t especially important since most use a PS.
rpschultz
Joined Nov 23, 2022
851
ok. I’m an ME, not an EE. A lot of this is new to me. I am still a novice scope user. What’s an easy test or 2 to try?
Plug the DUT output into Ch1. Leave DUT input open or apply a load? What would I measure?
rpschultz
Joined Nov 23, 2022
851
I made some plots last night on my Siglent SDS804xhd, still learning how to use it.
AWG providing 200 Hz.
Ch2 is my preamp that I designed. It runs at +/- 15v
Ch3 is a commercially available pedal running at +9.5v single sided.
rpschultz
Joined Nov 23, 2022
851
Since I started this thread, I have began to use REW (Room EQ Wizard) to test for THD, noise, THD+N, etc. It's free and pretty nice. But it has limitations, namely the audio interface used with it. I'm using a Motu M4, which is limited to THD+N of ~100 dB.
I have found 2 devices that could work better:
  • QuantAsylum QA403, 402, 401 - The 403 is $600 new.
  • Cosmos ADCiso - $350 new.
QA403 has it's own software, Cosmos would use REW. However, at this point I don't think my DUT needs better than what the M4 can measure. THD is in the 0.01-0.02% currently.
28,401
My much less scientific noise evaluation scheme is if it can not be heard in the speakers with no signal in but the gain turned up, then it probably does not matter. UNLESS you are recording for mastering DCs or cassettes. So far that has been accepted by most folks.
rpschultz
Joined Nov 23, 2022
851
Yeah less scientific but still valid, or at least still very practical. But at least measuring it in some official way allows for comparisons with similar gear.
