identifying a transistor from a 70s microphone
Deadpidgeon37
Joined Oct 21, 2023
3
i have a sony stereo electret condenser from the 70s. one of the transistors has failed but i cannot identify the transistor. can anyone help?
the code reads K39A CI2
the microphone is an ecm 99 if that helps.
dl324
Joined Mar 30, 2015
18,456
do you know where I can buy one of those or the modern equivalent?
I found this cross reference:
at https://masterelectronicsrepair.blogspot.com/search?q=2SK39A
I looked up specs for 2SK103 and found:
at https://www.web-bcs.com/transistor/tfet/2s/2SK103.php?lan=en
That lead me to Vishay J102, which is obsolete, but Mouser has some J201 from InterFET that look compatible:
https://www.mouser.com/ProductDetail/InterFET/J201?qs=OxRSArmBDfyvD8SbvWteMw==1697990095365.png
You can get a surface mount device for 10% of the price of the through hole part.
You can get these adapters for about a dime:
The leadframes are a dime each, if you can find them. You can substitute right angle male headers if the holes in the board are large enough. If it's a single sided board, you could enlarge them with a 0.035" (#65) drill bit.
If you have some copper clad board and a Dremel tool, you can make your own (shorter ones):
