Help for identifying burned IC no.
Electechcare
Joined Jul 6, 2026
Hi techies,
Help for identifying a burned LED driver IC, as on pcb pin connections designed as below mentioned.
1 - Negative
2-NC
3-input control signal
4- Output connected to LED through a inductor & one diode reversely paralleled
5 & 6 - shorted & connected to Negative
7- connected to negative through a capacitor
8- connected to Positive(24v) terminal through 1K resistor
Thanks in advance
Futurist
Joined Apr 8, 2025
952
Hi techies,
1 - Negative
2-NC
Thanks in advance
Why did you think no picture was a good idea?
