Identify this IC od suggest me a similar one with the same pinouts.
ali.malik
Joined Aug 28, 2023
5
IMG-20230828-WA0010.jpgIMG-20230828-WA0010.jpgcan you please identify this IC because there is nothing written on it or you can suggest me a substitute with the same pinouts. This circuit board is used in 8 program flashing led lights adapters.
Papabravo
Joined Feb 24, 2006
22,116
A custom microcontroller would be my #1 candidate. I know that answer is not much help to you, but picking your own favorite microcontroller and learning how to program it may get you to your goal quicker.
ali.malik
Joined Aug 28, 2023
5
How can i customised when i dont even know about this one. Can you suggest me same one ?
ali.malik
Joined Aug 28, 2023
5
I would be grateful if someone could help me out in designing a new circuit with the same components but a different IC for this 8 program led strip light adapter.
ali.malik
Joined Aug 28, 2023
5
Hi ali,
The nearest guess is this type of device.
Can you check the copper track under pins 1 and 8 , also 4 and 5
E
What is the module used to control?View attachment 301487
Pin 1 is connected with input current source, capaciter qnd one leg of the triac.
Pin 8 isnt connected to anything.
Pin 4 is connected with one leg if button , one leg of capaciter and a resister.
Pin 5 isnt connected with anything.
ali.malik
Joined Aug 28, 2023
5
Hi ali,
E
Hi ali,
E
This circuit board is used in this adapter.
Papabravo
Joined Feb 24, 2006
22,116
A custom microcontroller is fabricated in large quantities for a single customer. There is usually no public information on the pinouts or the functions of the internal program. If you want to duplicate or improve on the functions of the device, you can start with a microcontroller that has a publicly documented set of specifications you can use to develop a similar or improved product. Learning to program such a device is a challenging, but hardly impossible task. In any event it will be far easier and faster than to root around on the internet looking for information on a part you cannot identify or purchase.
ETA: go to the microchip website and look for an 8-pin member of the ATtiny or the mid-range PIC family of parts.
https://www.microchip.com/
