Identify component on a PCB
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Hello.
I have here a home appliance. It's a portable hoover. Not sure this is the correct name for the following appliance:
The problem with it is that all of a sudden, we couldn't stop the appliance. It was working even when we turned it off on the switch (3 states switch).
So, I disassembled and found a floating wire (black wire) and I soldered it to where it should be.
I'll share a few links with pictures I took from the "thing" this black wire should be connected to.
https://i.ibb.co/r5dCjzh/20220123-203932.jpg (this "thing" connects here in the PCB)
https://i.ibb.co/4V268nz/20220123-203839.jpg
https://i.ibb.co/ZfQh9k9/20220123-203902.jpg
https://i.ibb.co/k0FkLct/20220123-203635.jpg
https://i.ibb.co/6YBDC9q/20220123-203816.jpg
https://i.ibb.co/0fkmp03/20220123-203701.jpg
https://i.ibb.co/85NZVC3/20220123-203805.jpg
I have no idea what this is, but this is not accessible from the outside of the appliance. It was inside the case. I can only think this may be some sort of protection, because the metal plate of the red wire seems to be some sort of magnetic switch, as it is in a V shape and it's making contact with the plate of the black wire.
I'll try to represent what I see. If the '|' is the black wire plate and these 2 representations are the metal plate of the red wire "\ |" and " ||", they can combine themselves as position 1: |\ | and position 2 | || . Not sure you guys know what I mean.
Anyway, the reason I created this post is because, sometimes when I connect the charger to the appliance, the motor inside seems to want to start spinning, but it doesn't and it keeps doing this weird sound as if it is trying to start spinning. Other times, I connect the charger and nothing happens but a red led lighting up telling it's in charge mode.
When I connect the charger to the appliance and the motor tries to spin, I can feel at least one component going quite hot, so there is a short either in this component or somewhere else. But this only happens if the motor tries to spin.
The component shows only this reference: 4403 CT7A2 and I couldn't find anything like this.
I have a pic too:
I have removed this component and soldered it back to place, just in case it could be some pin shorted. But no luck.
I might also have to ask help with the switch because it may also be not in the best conditions, but that will be for later, if I have luck with this component!
panic mode
Joined Oct 10, 2011
4,985
yup, mono jack.
the last one is SOIC8 package but do not recognize the logo or marking... can you not post image of the product on PCB so we can see the surrounding parts too?
PsySc0rpi0n
Joined Mar 4, 2014
1,786
You guys can help me finding some equivalent mosfet models in case the shop where I use to go don't have this specific mosfet?
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Ok, I got hands on an equivalent MOSFET (AO4435) to the one in question and I'm going to replace it. The original one was heating up too much when I put the appliance to charge. So, I hope it's reasonable to assume that this MOSFET would be in short!
Now, just to make sure, is it safe to assume that the marked pin in the below image is where the IC pin 1 should be? Or is it the one on the right side of that same row?
sagor
Joined Mar 10, 2019
1,049
With the notch and little white circle, that is pin 1.
Check the PCB traces to make sure they match what the MOSFET pinouts are, regardless....
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Yeah, according to the tracks, that row has 3 source pins and one gate. The upper row has all the 4 drain pins as the datasheet shows.
I replaced the MOSFET but the behaviour is still the same.
I took some pictures of this board. Maybe someone have a clue of what else I can test/measure to try to sort the problem out.
I tried the motor out of the circuit, using my PSU. Despite the fact that my PSU can't deliver the required current, the motor works (by dropping the PSU voltage).
What else can I do?
https://i.ibb.co/r5sKKYM/20220131-173145.jpg
https://i.ibb.co/S6RhyhF/20220131-173223.jpg
https://i.ibb.co/jkZG4f3/20220131-173207.jpg
sagor
Joined Mar 10, 2019
1,049
It appears that Q1 drives the 8 pin Q2 via R37 (a guess). Check Q1, for if it is bad, it may be turning on the gate of Q2 100%.
Also, your Q3 looks like it has been running hot on that board. I would check that device as well.
PsySc0rpi0n
Joined Mar 4, 2014
1,786
How are you counting pins?
2 4 6 8
1 3 5 7
or
5 6 7 8
1 2 3 4
I assume one of the ways above. But by what I can see from the screen where I have removed the MOSFET, it seems R37 goes to the gate of the MOSFET, at pin 7 or 4 in the representations above.
Edit;
So, I can confirm that Q2 pin drives/is connected to MOSFET pin 7 (or 4) via R37 (2kΩ resistor)
Edit 1;
Can this component be identified?
It's the mentioned Q1
sagor
Joined Mar 10, 2019
1,049
Pins are always
5 6 7 8
1 2 3 4
on IC and devices that use IC layouts, such as this MOSFET. Pin 4 would be the gate.
Can't identify the NA or D? device. If D8, would be one thing, DB would be another...
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Pins are always
5 6 7 8
1 2 3 4
I can't tell for sure either. This is the best I can get from the usb microscope!
sagor
Joined Mar 10, 2019
1,049
Error in the pins, it is: (my mistake)
8 7 6 5
1 2 3 4
Always count counter-clockwise. I didn't look carefully at your arrangement once I saw the 1234 in the right order. However, for this MOSFET, the order of 5 to 8 does not matter, they are all tied together.
PsySc0rpi0n
Joined Mar 4, 2014
1,786
8 7 6 5
1 2 3 4
I was about to swear that I have seen different pin displacement. Anyway, how can I check if 3 Qs are good or not?
sagor
Joined Mar 10, 2019
1,049
Only way to test them is to remove them from the board and test with any common component tester. Those testers are cheap and can be found on sites like Ebay or Amazon.
You could test some transistors with a DMM, in diode test mode, to test the junctions of regular transistors. There are ways to test some MOSFETs, check youtube videos....
PsySc0rpi0n
Joined Mar 4, 2014
1,786
Those ebay/Amazon testers are mostly for 3 pin components. At least that SOIC8 can't be tested there unless I solder 3 wires to it and give it a try. Same for the other ones. But I can do that, for sure!
sagor
Joined Mar 10, 2019
1,049
The pins on the 8 pin device are connected internally, so in effect it is a 3 active pin device. No need to solder wires to it. Just test between any pin 1-3, pin 4, and any pin 5-8
