RESOLVED - Identify this component
Tonyr1084
Joined Sep 24, 2015
9,744
In my Launch Controller I have a diode that's supposed to shunt capacitive charge of a 4700µF cap. A 1N4001 is good to 1A. Want to channel 12V through a diode and series resistor (100Ω) to quickly discharge the cap and make the launch pad safe from accidental firing of a rocket that is in the process of being armed.
There are two 100Ω resistors in parallel. One conducts only one way.
I get 12V ÷ 50Ω = 240mA. Is that right? Should be, but a cap can deliver its full charge in nearly an instant. Should I use a smaller resistor (in series with the 1N4001? Can I get away with two 50Ω resistors?
panic mode
Joined Oct 10, 2011
5,202
that is not complete circuit but it looks scary. i would not want to see ANY power around igniter when armed switch is off.
if using capacitor to pad the battery, i would put it before armed switch (and make power switch DPDT to discharge it quickly).
Tonyr1084
Joined Sep 24, 2015
9,744
Can I use a Germanium diode in place of a 1N4001? It's only passing an output from a 4017 to a 4083 (2 in AND gate).
Why do I ask? Because I have 100 of them. How? Why? Heck if I know. At some point I was thinking about a crystal radio. Lots of things I planned but never started.
bertus
Joined Apr 5, 2008
22,995
Germanium diodes most times have a low maximum current.
Think of the max current as 50 to 100 mA, dependend of the type.
Try to find a datasheet of your diode.
Bertus
Tonyr1084
Joined Sep 24, 2015
9,744
How much current would be between outputs of a 4017 to an input of a 2 in AND gate? Can't be that much.
Oh, and I did find a data sheet. alldatasheets.com had nothing. Guess it's an old and possibly outdated component.
bertus
Joined Apr 5, 2008
22,995
What diode do you have?
The internet archive might have old databooks.
Also bitsavers carries a lot of old databooks.
Bertus
sghioto
Joined Dec 31, 2017
8,749
Don't see the need for the diode. The cap will fully charge or discharge in appx 2.5 seconds through the 100 ohm resistor.
Tonyr1084
Joined Sep 24, 2015
9,744
Thanks. How did you arrive at that figure? I would have no idea how to go about that. And I'm sure it's quite easy. Maybe if I learn it and practice it a few dozen times.
sghioto
Joined Dec 31, 2017
8,749
I used the "Capacitor Charge and Time Constant Calculator" on the AAC website.
Tap on the Menu bars and scroll down to "Tools" then "Calculators."
