Can Anyone Help Me Identify the Right Component for a MIDI Controller I'm Building
denni
Joined Jul 18, 2023
65
Hi everyone,
I'm trying to design a compact MIDI controller and I'm still struggling to choose the right component due to my limited knowledge of electronic components. Actually, I'm trying to find a part that functions like an encoder but with a limited range of rotation.
Here’s what I am looking for:
  • I want the control to turn clockwise from a minimum value at about 7 o'clock to a maximum value at about 5 o'clock ,as the encoder used in Dj equipment
  • The encoder should not rotate infinitely; it should have a defined start and stop point (like a volume or Eq/filter knob on some audio equipment).
I’m confused about whether I should be looking for a rotary encoder or a rotary potentiometer to achieve this effect. If anyone can clarify what component I should be using, or if there's something else entirely that fits this description, I would really grateful for that.
Thank you.
38,859
A pot handles analog signals, while an encoder handles digital.
Which type of signal are you controlling?
denni
Joined Jul 18, 2023
65
Hi, and thank you for your answer, Sir. I’m aiming to control MIDI CC messages with the encoders. These encoders will send MIDI CC values ranging from 1 to 127, which I plan to use for various controls such as filters, EQs, and other parameters.
What I’m looking for is an encoder that allows me to achieve these values within a 270-degree rotation (from 7 o'clock to 5 o'clock), rather than requiring multiple turns. The goal is to have the minimum value at the 7 o'clock position and the maximum at the 5 o'clock position. I’m trying to replicate the behavior of some encoders in MIDI controller I have, by creating a new : The reason I need to chose the rigth electronic components.
Alec_t
Joined Sep 17, 2013
15,158
Since a potentiometer for your application is likely to get quite a hammering, be sure to get a good quality one.
