Identify part/component on PCB in some video monitor
ronsimpson
Joined Oct 7, 2019
4,901
Standoff Here is a data sheet for two kinds of standoffs that "rivet" into the PCB.
The " solder points " are probably just VIAs. When current flows through a standoff it is common to put VIAs around the mounting hole to lower the resistance.
I cannot see the other side of the board to know for certain.
Techsas
Joined Dec 3, 2025
6
Thanks.
I helped a colleague many months ago with this monitor. We are not pro in electronics (him way less than me), so sometimes we open faulty equipment to look for obvious problems, burned or corroded parts, and I dont remember what the problem was, not even brand or model. It was his field, not mine...
Just took the photo. I should have looked at what was underneath. The pcb has two black screws, I now notice, so not neccessary with some positioning-pin, and absolutely not that big.
Maybe som mounting/threading for something on the other side, who knows...
I thought it could be some sensor, shaking sensor maybe, but dont think so actually... the soldering was strange - solder on each side of the small holes, but not the holes...well...
Thanks anyway.
Edit: Could it be some coil, dual/quad coil???
The line beside is marked H4... (transformer?)
Techsas
Joined Dec 3, 2025
6
I can see H4, H3, H1 and there appears to be one more. H=hole in this case. It is very common to have Mounting Holes in the corners.
Youre absolutely right.
First now - I see all the solderings are connected on the same track/layer, and just now I catched the other one in the opposite corner.
You think its the end of the screw, the shiny surface in the middle?
Techsas
Joined Dec 3, 2025
6
What is the H2 component?
Can I measure if its OK or faulty?
Its in a pro Li-Ion battery ($500 range) taking no charging anymore (not totally dead, but no charging possible, except for feeding the cells directly/internally).
Techsas
Joined Dec 3, 2025
6
Not sure why my latest posting got moved to this thread, it was supposed to be a different thread with the following title:
Identify SMD-component marked H2 and PCB marked FR1...?
(I will give it a new try, posting as separate thread)
