Ideal op amp
WBahn
Joined Mar 31, 2012
33,122
Can you give a picture c about what you mean in the bold line?
No. I'm not going to spend a bunch of my time drawing 200 batteries.
Which part of the following pieces is tripping you up?
1) Put 200 1.5 V batteries in series.
Imagine them lying on their side, end to end, the negative terminal of each on the left, the positive terminals on the right.
2) Connect the negative terminal of the left-most battery to 0 V ground.
3) What is the voltage between the positive terminal of the right-most battery and ground?
linhvn
Joined Nov 6, 2024
297
No need upto 200 batts. Just a few is enough because the same naturally. It is not what you said, not correct.
WBahn
Joined Mar 31, 2012
33,122
So the voltage at the top is NOT 5 V, even though that point is connected directly to a 5 V source.
Think about that and now go back and look at where you drew the conclusion that Vn was 2 V because it happened to be connected directly to a 2 V source.
