I have a need to start, and stop a diesel engine that we are using as a power unit.
I am thinking we can do this using a PLC, but I am by no means profecient with PLC's. Here is the info about this homade power unit.
It is an all mechanical 6V53 detroit diesel. This system will have to operate on only 12v DC. It will be out in a field with somewhat limited access.
So. I am looking for advice on the type and construction of what will be needed to make this work. And as usual the cost must be kept as low as possible, $3.00 corn does not buy much these days.
This power unit will be hooked up to a drainage pump connected to a float switch. we will have a solar powered 12v battery maintainer on it as well.
I have attached a basic flow chart as to what I am looking to do. keep in mind it is basic. I do have a very good CNC machining skills and have used robotics in my past, but never had the opportunity to get into PLC's much. I also understand basic inputs and outputs and so on.
Any and all help on this project will be greatly appreciated!
