How's the weather?
Joined Nov 30, 2010
18,224
Finally got some rain yesterday, and a bit of surgery a week ago. It gave me a bad attitude for a week!
What? You couldn't tell the difference?
I'll try to do better in the future.:oops:
GopherT
Joined Nov 23, 2012
8,009
Since you brought it up, are we turning this into a guessing game? I just saw an article about bizarre cosmetic surgeries so I'll guess your surgery was either eyelash embellishment or belly button reconstruction.
killivolt
Joined Jan 10, 2010
836
Sorry to hear about that, High and Low pressure has been messing with my lower back for the last couple weeks. I put down more weed and feed while it was raining, the lawn is looking greener than ever before. Time to plan running a new main water line to the house and install a stop and waist, finishing it with the distribution valve box and run control wires. All the pipe and sprinkler heads are in the ground waiting since last fall. I have a quick disconnect Bibb for front and back, I just connect a hose.
My Dad died this year and won't be doing much in the Smoker Thread, but if his house sells quickly I may get time.
Get well soon,
kv
Joined Nov 30, 2010
18,224
It was a dental thing. One tooth had a, "root canal and a crown" for almost $2000. That changed it from "having a cavity in an inconvenient place to drill" to "hurts when I chew and is so sensitive that I'm afraid to floss it".o_O
"No problem. Just pony up some more cash and we'll cut that two thousand dollar tooth out and throw it in the trash.
ps, No refunds on my failed adventure and your permanent loss. Have a nice day!":)
See? I got a bad attitude from that experience. Besides, I still have owies and places not to put a tooth brush.:(
spinnaker
Joined Oct 29, 2009
7,830
Did you get a gold tooth as the front tooth? That would be way cool. And you would be irresistible to the ladies. ;)
Joined Nov 30, 2010
18,224
Well, $2000 would buy enough gold to make one or two teeth, but no, I didn't get any gold teeth, tooth number 3 is not in the front, and if it would attract women, no thanks. I've been struck by that kind of lightening enough to learn why I shouldn't do that.
OK. Laundry is about done. Time to go to the food store. Then I get to remove the radio controller I installed in my computerized car because it made the fuel gauge quit working.:confused::mad:
The wiring diagram shows that the fuel gauge is not connected to the radio/window motor circuits, but it quit working when I added a relay to turn off the radio when I turn off the engine. I'm really struggling to stop myself putting a bullet in this car...or the guy who designed it. So many microprocessors, so many errors in the wiring diagram, so many digital transponders instead of switches. I can't even connect a wire to the door switch to control the dome light because it isn't a switch...it's an input to a microprocessor.:mad:
cmartinez
Joined Jan 17, 2007
8,850
Remember, doctors and dentists are only, "practicing". They accept no responsibility to get appropriate results.
You need a job where you get paid to practice.;)
As opposed to technicians and engineers, who get paid to "solve" ... as in: "I couldn't solve it? ... then I don't get paid!"
Joined Nov 30, 2010
18,224
That or just find something to blame it on when something doesn't work as planned. That worked for me for over 30 years.
Ron
I suspect you had a government job.:D
In my world, the only thing that can go wrong is me. If it doesn't work, it's because I didn't make it work.:(
shortbus
Joined Sep 30, 2009
10,049
Now you know why they're called "Ford Exploder's" :) all of you long term owners are doing the 'beta' testing.
Joined Nov 30, 2010
18,224
I think there's a different reason, but the trend of installing a handful of $2 microprocessors that cost $1000 (each) to replace seems to indicate that the Beta test is about how many people will still be able to afford cars when an average repair costs so much.:( I pray regularly that the engine control MPU is much more reliable than the unnecessary frills and gizmos like, "puddle lights", self-dimming rear view mirror, and keyfob entry systems. All that computing power, Vehicle Security Module, and 5 or 6 lock solenoids to avoid putting a key hole in every door? Not my style!
I have unplugged the wires to the puddle lights, the self dimming rear view mirror, the, "Beep-Boop" sound, the horn blowing in the night feature, the automatic battery killing headlights, the ceiling window motor, and the electronic compass. I zip-tied a micro-chipped ignition key to the Security Module so I can start the car with a $4 key and added a relay to get the radio to turn off when I turn off the engine...and that is not even half the gizmos I have defeated. As far as I'm concerned, the last good invention was Interval Windshield Wipers. They should have stopped there.
I will probably cuss this car until the day it dies, but buying a newer car seems to only accomplish getting more MPUs.:(
ps, Occasional showers creeping into the daily forecasts as the dry season slowly turns into the rainy season.
The heat isn't bad yet, but the tropical sauna is slowly arriving.
