Sorry for the lack of progress once more while waiting for the mailman, however I scored a 3 jaw chuck for my lathe that appears to be in new condition if not new and never used.
Sadly, it did not come with a face plate to attach to my lathe, so I decided to take on a bit more than I could chew and see if I could use my limited skills to make an adapter that would allow me to use a face plate that I had here which does attach to my lathe and see if I can match it up to the new chuck.
The adapter required 1 face to have a machined impression in it, while on the other face it required a raised circular center piece to cup into the back of the new chuck.
Not being familiar with how to approach it I found a scrap piece of 8mm thick plate and cut a square piece which fitted nicely into the jaws of my 4 jaw chuck.
Long story short, I machine both faces to a nice neat fit and cut a hole in the center.
After finishing the 1st face I had to flip it to do the other side, that was when I realised that I would probably lose some accuracy.
Nevertheless, I finished the impressions, then cut off the corners and mated the face plate and chuck together with some new bolts and machined down the outer edge to match the diameter of the chuck etc.
I then set it up im my lathe and did a run out test.
Sadly, I was about 18 thou out.
From what I have learned that is not good.
I fooled arounded with it and could not improve it, so I fell back to my bush skills and made it worse, now over 25 thou.
I took a look on YouTube and found several methods of correcting this issue using more technical methods and will next attempt to apply one of these methods to reduce the run out.
For me anything under 10 thou would be a big improvement and with my lathe skills I think I'd be happy with that in a 3 jaw chuck, considering if I want precison I'd go with my 4 jaw chuck.
In hindsight, I should have only machined the face that mated with the face plate and installed to the face plate and then installed this unit onto my lathe and proceeded to complete the 2nd face.
I feel sure that would have helped me greatly to minimise run out.
All the same I've learned something and have gotten a new 3 jaw chuck that attaches to my lathe and will eventually be accurate...
If nothing else this post will provide a good belly laugh for those who are really machinists...
