How to rewire old food processor motor
MaxHeadRoom
Joined Jul 18, 2013
30,877
These motors are often variably controlled with a simple triac 'dimmer' style controller, they operate in a run-away condition, IOW the RPM depends alot on the load as well as voltage..
Being series field, they have a fair amount of torque.
Max.
lookingforhelp
Joined Jan 9, 2020
23
There is two filed wingdings Some are wired Field -armature- field. all in series, ensure you connect the two field up so they are wound in the same direction as below.
In some cases the armature is between the filelds, others the armature is after both fields.
Max.
Ill draw a diagram of this motor so i can show it better. I feel like my explanations werent that good.
Dodgydave
Joined Jun 22, 2012
11,395
Your motor has both field windings separate wired, so you must make sure they are in series the same way or the motor won't run, here is a video of how to test it on a battery.
lookingforhelp
Joined Jan 9, 2020
23
If you are nervous of energizing from 120/240 etc, try it first on low voltage, a automotive battery should show results.
Max.
heres a crude drawing of the motor. i did it in paint since photoshop didnt want to launch...
Would the motor move with low voltage? Its a 230v. I guess it would move but not with the correct rpm. I also would guess its an AC motor?
MaxHeadRoom
Joined Jul 18, 2013
30,877
It is a Universal motor, so it will operate on AC or DC.
Even at 12vdc, it should spin up to some degree to show it is operating OK.
Wire the motor power to one field through the armature to the other field, the second field will be connected to the other power conductor. i.e. series.
Try it on L.V.
If it does not spin, swap conductors on one field.
Max.
lookingforhelp
Joined Jan 9, 2020
23
Try it on L.V.
Max.
would this work? or how should i wire it? and i guess polarity doesnt really matter.
lookingforhelp
Joined Jan 9, 2020
23
Try it on L.V.
Max.
i got it working. Thank you for the help. It wouldnt be running without it :D
