How to rewire old food processor motor
lookingforhelp
Joined Jan 9, 2020
23
Okay so i have a food processor motor but i cant find a wiring diagram and would need help how to wire it to work as a generator or just as a on off motor.16108856242335741956043065802753.jpg16108856434208884383681301269178.jpg16108856589911464202971392384902.jpg
Ramussons
Joined May 3, 2013
1,572
How many wires does it have? What are the resistances between these wires?
Normally, these are Universal Series motors with the number of wires = 1 + number of speeds.
MaxHeadRoom
Joined Jul 18, 2013
30,885
I would imagine a food processor is just wired for one direction, it will not work as a (DC) generator without some changes, you would need to feed the field separately with a DC power, the armature should then generate when rotated.
As it is, it will run on DC or AC.
Max,
lookingforhelp
Joined Jan 9, 2020
23
I cant measure the resistance right now but will do later next week. 5 cables. Red, yellow, black, white and brown. 4 cables seem to be attached to the field windings. I guess the different speed settings. The black one looks to be attached in a few places
lookingforhelp
Joined Jan 9, 2020
23
Max,
Yea i saw somewhere that you need to put power to the field windings.
MaxHeadRoom
Joined Jul 18, 2013
30,885
The black wire goes through the thermal sensor to one of the armature brushes.
The other is the red wire to the field, the other side of the field should be connected to the other brush.
Looks like the yellow is the other field?
So red & blk is the applied power ?
The bottom line is both armature and field should both end up in series.
Max.
lookingforhelp
Joined Jan 9, 2020
23
Max.
The white one is the other brush and yellow and brown are attached to the other field.
lookingforhelp
Joined Jan 9, 2020
23
How would i power this to see if it works properly. I guess i could just plug it into the wall but it doesnt sound very safe. Ill probably have to find a switch for it also
MaxHeadRoom
Joined Jul 18, 2013
30,885
There is two filed wingdings Some are wired Field -armature- field. all in series, ensure you connect the two field up so they are wound in the same direction as below.
In some cases the armature is between the filelds, others the armature is after both fields.
Max.
