Rewire Ikea Rolfstorp
Ian0
Joined Aug 7, 2020
13,188
I see an inductor in there, that means there is a switched mode supply for the LEDs.
See if you can identify which device is controlling the switched mode supply by following the tracks from the inductor.
Then find its datasheet and see if it has an "enable" input.
Alternatively, but rather less likely, the LEDs might be switched by a power transistor after the switched-mode supply.
Tapesync
Joined Mar 13, 2023
Sorry for the stupid question, but which one's the inductor?
Tonyr1084
Joined Sep 24, 2015
9,744
It appears to be battery powered. If you want it on when it gets power just put the battery in and touch the pad once and it will be on until you pull the battery or it goes dead. Unless you're planning on using a different power source. As for tracing out the circuitry, that's not going to be easy, and possibly not possible due to what looks like a multi-layer PCB. That's not a cheap lamp, not if it's multi-layer PCB construction.
Usually we try to answer the question as posed. Sometimes we offer an alternative solution. My suggestion is to get a lamp that is simply powered from a source (AC or DC) and may have a switch. Switch it on and forget it - or however you intend to use the lamp.
Tapesync
Joined Mar 13, 2023
It's actually about 10$ - so nothing overly fancy.
It can be powered using batteries or Micro-USB.
Readeon
Joined Apr 7, 2023
Don't know about OP, but personally I want to be able to turn it on and off using WiFi outlets.
Have exactly same idea to control it with smart outlets. Thought maybe the controller can be “enabled” for the default on/off mode? Just trying and welcome suggestions.
ElectricSpidey
Joined Dec 2, 2017
3,346
Is that a capacitive touch switch?
Perhaps a small cap or resistor from the switch to one of the rails, to serve as a sort of POR... I don't know that's just a wild idea.
27,874
I believe that "inductor" is actually a battery contact spring, as the device is dual powered. So separating the touch function from the LED power system may be a serious challenge. AND, some of us just plain do not like touch switches.
ElectricSpidey
Joined Dec 2, 2017
3,346
I know Ian0 is old, but I don't think he is old enough to confuse a battery contact spring with an inductor yet.
_emi
Joined Jul 31, 2023
This LED-lamp has a touchsensitive button. I'm wondering if there is an way to solder a cord between to points, so the LED turns on as soon as it get power? Ignoring that pesky button.
hey ironyman, did you ever find a solution? just bought two of these expecting them to be smart switchable, only to find i'm stuck with that annoying button
27,874
Itshould be possible to bypass the touch switch portion, BUT probably there is also a switching regulator portion that is not good to bypass.
Dodgydave
Joined Jun 22, 2012
11,395
Can you take sharper pictures of the chip numbers, one of them will be the touch button chip, ..
27,874
OK, here is the situation: That circuit board has both a touch switch, which might control more than just OFF/ON, AND a switcher-mode LED driver system. Doing enough analysis to locate the division between the two will be rather complex, given the large number of components. The PCB is at least double sided, I doubt that it is multi-layer though.
So converting it to an externally controlled scheme would be a major hack
But there might be some scheme to force it to switch on when external power is first supplied. Read the literature that came with it.
