How to modify/ design error amplifier compensation circuit (with TL431) for variable flyback converter and make it stable.
polashd
Joined Jan 16, 2014
7
I bought a power supply adopter (old, used, made for some device) of 24v 4.5A (from 230vac mains). It is a fixed output psu. My intention is to make it a variable psu of 30v to <=5v (as low as possible, and continuously variable). Schematic (simplified) of its error-amp circuitry is attached below.
I tried the following methods (varying different component values)-
1) Replaced R_lower2 with a 10k Pot (Rv_lower1 is a variable resistor of 2k- adjusted to ~1k by manufacturer).
2) Replaced R_upper1&2 with a 100k Pot.
3) Replaced R_comps with a 100k Pot.
4) Removed DZ1&2 and connected the err_amp to a 12v source (common ground -Gnd_B).
Whatever I did ends up to same situation- up to 16v it goes without any problem. But when I try to lower the voltage further the output becomes very unstable.
I searched internet (including youtube, chatgpt3.5) and got the idea that the problem is with the compensation network of the error amplifier.
I also got some good documentations on the compensation network which describe about – transfer function, bandwidth, frequency response, poles & zeros and many more things. As a simple hobbyist these terms and equations are very complicated for me. I don’t understand where to start, how to proceed and steps involved.
Can anyone please help me in this? What should be the values of different components, how do I calculate step by step (so that a hobbyist like me can do it, for continuously variable psu).
Note:
a) in the schematic I added TL431, in actual circuit it’s AZ431.
b) I didn’t get symbol and .lib/ .sub for LD7575PS- so I edited symbol of another ic in ltspice.
c) as per the equation in the datasheet of PWM IC –for a 120k resistor from RT to ground the switching frequency sb around 54kHz.
d) If possible provide me a working simulation schematic (with symbols and .lib/ .sub of important components like TL431 (or AZ431), optocoupler (in the PCB it is EL817), etc).
e) Can I do it with an op-amp (without TL431, achieve even lower output voltage like <3v).
Pyrex
Joined Feb 16, 2022
551
it seems, 431' is not a problem. Problem is the topology of the PSU. If it 's a flyback PSU, it's optimized to output 24V. And a minimal current to be provided. Flyback can't work if output current falls significantly. So, usually in such a PSU a big power resistor at the output is provided to maintain the minimal current.
If it's a half -bridge topology, the situation is a bit better.
In any case, circuit diagram of the PSU is very helpful.
One more question- how the PWM controller is to be powered , if it's powered from the same transformer and output is lowered, say to 5V?
polashd
Joined Jan 16, 2014
7
It is powered from the auxiliary winding of the transformer.
While testing- i use 47ohm power resister as test/ dummy load which draws 400ma to 500ma.
Pyrex
Joined Feb 16, 2022
551
It is powered from the winding of the same transformer, right? So, if 5V is set in 24V PSU ?
It is wise to provide a separate small power PSU for PWM controller to have a stable and constant voltage for the controller.
Anyway, flyback is not a best topology if you want to built a laboratory PSU
polashd
Joined Jan 16, 2014
7
you were right (thanks a lot). Chatgpt misguided me from the beginning by saying that its a compensation loop (of error-amp) problem.
I disconnected the connection from auxiliary winding, powered the control circuit using a 12v adopter and some other changes in the secondary (mostly various resisters). the output now can be adjusted down to 2.6v.
I want to replace the 12v adopter, power the control circuit from main DC input (~305v, rectified from ~230v AC) using voltage divider-diode-capacitor- zener diode (of ~20v). the controller IC works from 10v to 30v. Can I (should I) do it.
The reason of doing this- 1) I need to use one in the secondary to power an op-amp (maybe used for current limit. voltage feedback works without any separate power source), 2) as it's a pre-made power adopter (for some device) i have space problem.
