how to measure the current consumed by dc motor
  • Thread starter Deleted member 618306
  • Start date
Joined Dec 31, 1969
in this circuit
without DMM the motor is running fine.
with DMM the motor is not running.
the scope here is to measure the motor current through DMM.
i tried 6 and half also. cant get result.
anyone please help me out in this regards.
any idea about measuring using arduino uno?
oz93666
Joined Sep 7, 2010
742
The resistance of DDM is reducing the current in the circuit so the motor won't run ... You need a clamp meter .. it is not connected to the circuit , but has jaws which clamp around the wire .....
If you can't get one of these , but do have variable power supply you can get a rough idea by first running the motor as it would normally do and note the speed ... then connect the DMM and power motor with variable supply , turn up the voltage till motor runs at same speed as before and read current.
