Isolated current sensor or sensing amplifier suggestion required to measure very low current 0-200mA
Avinash B P
Joined Mar 2, 2022
19
Hello
I am looking for the isolated current sensor amplifier with single ended output to measure 0-200mA in one of my circuit. sensing will be at high side. or any hall effect sensor those are suitable for low current sensing.
Regards
Avinash B P
Marley
Joined Apr 4, 2016
519
The proper way to do this - if you want to measure isolated DC current is to use a Hall Effect transducer.
This packaged device described in the link below gives out a DC voltage in proportion to the primary DC current.
The input range for this device is +/- 1.7A but if it can be made more sensitive by winding a number of turns through the core as the primary. Example: 8 turns at 200mA will equal 1.6A.
https://www.farnell.com/datasheets/2149975.pdf
