i tried to give as much info as i could..Your info is limited as per post #15
yes..i have the amplified guitar signalThe mp3 player can drive the LM386 directly.
The guitar pickup is not the same.
Can the guitar output drive the LM386 to your satisfaction ?
The higher impedance the guitar input - the more sustain.The mp3 player can drive the LM386 directly.
Some of the Philips electronic engineer kits did a mono to stereo amplifier - all it actually did was split the mono signal into HPF & LPF circuits so the 2 speakers produced different frequency ranges.Mono input will not result in a stereo output
You sort of do with a BTL amplifier - but the 2 amplifiers are driven by identical but anti-phase signals.And you cannot sum the output of power amps as you have drawn.
You need to process the stereo and mono inputs before the power amp. One stereo power amp will do the job.
i was thinking abt this. .what should i use for buffering?? lm386 ??Hello,
To avoid intermixing (cross talk), you could use two buffers on the mono signal and connect the outputs of the buffers to the mixer @Dodgydave posted.
Bertus
i am following something like this..will let u know the results..thanksLook at the link I posted.
You should get an idea.
