how to make stereo mon mixer
R!f@@
Joined Apr 2, 2009
10,014
The mp3 player can drive the LM386 directly.
The guitar pickup is not the same.
Can the guitar output drive the LM386 to your satisfaction ?
R!f@@
Joined Apr 2, 2009
10,014
Follow this page, study it and get back.
You can make 3 circuits as in figure 1.
1 for Guitar, 2 for mp3 left and right..
then mix them as in figure 2 , L + R, then feed the output to the stereo power amp.
{ed}
To avoid channel mixing you can use 2 for guitar amp.
Just tie the inputs together and feed the output to L and R seperately
Dodgydave
Joined Jun 22, 2012
11,395
You need a stereo mixer amplifier like this example , input your mp3 into L1,R1 and the guitar into L2,R2 ( note you link l2,r2 together) and the signals will be mixed..
bertus
Joined Apr 5, 2008
23,029
To avoid intermixing (cross talk), you could use two buffers on the mono signal and connect the outputs of the buffers to the mixer @Dodgydave posted.
ian field
Joined Oct 27, 2012
6,536
The higher impedance the guitar input - the more sustain.
Some tube guitar amplifiers have a grid leak resistor as high as 6M8 on the first stage.
Dod produced a nifty little JFET pre-amp, I think the leak resistor was 3M9.
ian field
Joined Oct 27, 2012
6,536
Mono input will not result in a stereo output
Some of the Philips electronic engineer kits did a mono to stereo amplifier - all it actually did was split the mono signal into HPF & LPF circuits so the 2 speakers produced different frequency ranges.
ian field
Joined Oct 27, 2012
6,536
And you cannot sum the output of power amps as you have drawn.
You need to process the stereo and mono inputs before the power amp. One stereo power amp will do the job.
You sort of do with a BTL amplifier - but the 2 amplifiers are driven by identical but anti-phase signals.
R!f@@
Joined Apr 2, 2009
10,014
You did not study the ESP pages I showed you.
Buffers are OPAMPS like TL071 or TL072 used before the LM386
Samantha Groves Analog & Mixed-Signal Design 17
M Technical Repair 23
Z Analog & Mixed-Signal Design 11
