I have two square-wave signals. I'm using one to turn on the other. Need to open the gate when the slower signal goes low. Using N-channel works well (top trace is output):
http://tinyurl.com/y8ddbt7a
However, i'd like to square-wave at the drain to be inverted at the output. Is there a way to achieve that without adding another transistor?
Changing to a P-channel doesn't help. Exchanging the clocks doesn't help.
