How to make FET invert the drain?
johnyradio
Joined Oct 26, 2012
615
I have two square-wave signals. I'm using one to turn on the other. Need to open the gate when the slower signal goes low. Using N-channel works well (top trace is output):
http://tinyurl.com/y8ddbt7a
However, i'd like to square-wave at the drain to be inverted at the output. Is there a way to achieve that without adding another transistor?
Changing to a P-channel doesn't help. Exchanging the clocks doesn't help.
johnyradio
Joined Oct 26, 2012
615
thx for running that! But, i want to get output when the low-freq goes to ground. In yours, we get output when the low-freq goes high.
AlbertHall
Joined Jun 4, 2014
12,663
Connect both signals to the gate via diodes, cathode to the gate, and add a resistor from gate to ground (10k?). Connect the drain resistor to a power supply.
38,952
:rolleyes::rolleyes:
Do you mean anode to gate so that the diodes act as an AND gate?
Also the 10k resistor from gate to V+?
LTspice simulation of that below.
Possible disadvantage is that the gated "off" output voltage is +5V, not 0V.
Bordodynov
Joined May 20, 2015
3,435
Hi.
The first thing I want to say is that the original (first) diagram is not correct (absurd).When 15 Hz has a high level the output will be zero.Nevertheless, I propose a scheme in which the output is inverted (inverse).
See
AlbertHall
Joined Jun 4, 2014
12,663
Errr...Ummm...
From the original post looking at the circuit, When the gating signal is high the output will be low, but in the waveforms shown when the gating signal is high the output is high.
To match the circuit the diodes need to be cathode to gate (OR gate), to match the waveforms the diodes need to be anode to gate (AND gate).
johnyradio
Joined Oct 26, 2012
615
thx for replies, many thx for time y'all spent coming up with solutions!
Apologies but i found a workaround for my needs, so i don't need to do the topic of this thread for now.
feel free to keep discussing :)
