How to make a 20 LED chaser with 4017 ?
sarahMCML
Joined May 11, 2019
707
I would not expect that 7400-series TTL devices will operate adequately in conjunction with CMOS devices.
They'll be fine at driving the TTL, although as I suspect q12x is using 74LS74's, the resistors should probably be made no larger than 2k Ohms, to satisfy the Low level input requirement. I mostly use HC or HCT versions, so I don't care!
28,626
Given that the discussion started out with CD4017's, which are about "as CMOS" as can be, I would stick with CMOS, because I prefer it, and with only one family there are fewer potential issues. And besides, CD4013 devices are so easily available.
sarahMCML
Joined May 11, 2019
707
I agree with you, whether it's the older CD or the newer HC, HCT or even newer versions, CMOS rules for numerous reasons.
sarahMCML
Joined May 11, 2019
707
I've just realised that my circuit in post #40 is wrong, the connections going to 4017 outputs 2 & 3 need to be swapped over, so that the 2 gates that are together go to output 3.
q12x
Joined Sep 25, 2015
2,245
Im always forgetting about these types and you always have to remind me about them. I will never learn.
I had some very bad experiences with SOME CMOS ICs - I forget which ones they were, but in my entire history of electronics, where they had absolutely no ESD protection on their pins and they just DIEEEEEEEEEED by simply touching them. So.... I learn quickly to stay on the LS side (low-power schottky) which is TTL. But mostly the cheapest logic ICs I could find, dictates what I have now.
You dont have to suspect anything, you have my IC list, remember? And yes, I have 7474-74LS74 17/20.
q12x
Joined Sep 25, 2015
2,245
This is the pulse output version of the circuit I suggested earlier this morning!
If you don't have any OR gates, just use NOR's and put the 2 unused gates on the outputs as inverters!
I made your 2xOR version and is still giving errors on the output.
But it is switching left and right at the correct times (B_FF). It is not switching correctly the (-) rails, responsible is A_FF. And is repeating 3 times until switching (-) rails in both senses
I had to tweak the osciloscope quite a lot until I got these readings and you observe the last yellow line (A_FF input) is positive and is right at the very end. The blue is for (B_FF input)
It is doing the pulse alright but I believe the FF's are not catching the pulse quite right. The same issue was with my initial pulse gen.
I think yours is better.
1714896165286.png - The solution is to widen this pulse signal !
We need to insert a bit of delay in this pulse mechanism. Hmmm...
sarahMCML
Joined May 11, 2019
707
View attachment 321649 - The solution is to widen this pulse signal !
See my corrected version of post #40, which does switch the FF's in the correct order. However, you may have to reset the FF's with the same reset pulse that resets the 4017 each time round the loop to maintain the correct output sequence!
You'll need to invert Q4 and use it to reset both FF's!
If you put an LED + resistor on the output of each FF, and clock the 4017 slowly, you will see the sequence easily.
q12x
Joined Sep 25, 2015
2,245
another try
the tests were promising but when put into my cct, failed. Couldn't clock anything.
q12x
Joined Sep 25, 2015
2,245
Hmmm, I believe I find the problem. You see that blue btn in green square. He is 0 all the time, 1 when is pressed and then returns to 0 when I release it.
When I did the tests, I used that type of button. Now, in the cct, those CLK pins are staying High for some reason. We need to keep them Low all the time, and when the pulse is activated, will go 0-1-0 and remain on 0 even after 4017 clocked next.
Ok, I changed those 2 10k into 1k and both CLK pins are staying Low all the time.
But the output is still erroneous.
Ive added 1k to the AND gates, maybe was too much current surge. I THINK... but not sure, it influenced it a bit/changed the behaviour a bit maybe?
This is a movie, not a picture, see -link-
You can see is starting ok but after some passes, is going in error land.
Those red marks are the recent changes + overall look of the cct.
sarahMCML
Joined May 11, 2019
707
Forget what I said about the amended circuit in post #40, it doesn't work in practice, and is indeed far too complex. ALL that is needed in fact is to connect Pin 2 "1", and Pin 7 "3", to one OR gate, connected via the cap and resistor/diode arrangement to FF "A". Then just connect Pin 4 "2" to the other gate (both inputs commoned, as a driver), then via the capacitor, etc, as before, to FF "B". That DOES work, I have it running on my bench now!
It does need the reset from the 4017 connected to the FF resets via an inverter if using 74LS74's. This wouldn't be the case if using a CD4013 though.
q12x
Joined Sep 25, 2015
2,245
Like this?
Still, erroneous output.
sarahMCML
Joined May 11, 2019
707
Like this?
You haven't added the Reset circuitry that I used with my circuit. It's essential, otherwise the FF 's can get out of sync and flip to the wrong states.
Just connect both FF Reset pins (Pin 1's) together and connect them to the output of an inverter. Connect the inverter input to the Reset pin on the 4017.
q12x
Joined Sep 25, 2015
2,245
And Congratulations ! Thank you ! Now is working !
The correct way, a sample movie, see -link-
Here is the final working cct.
That NOT gate can be made from 1 tr.
All those AND gates can be replaced by NPN tr's with a common Base; (or Mosfets).
q12x
Joined Sep 25, 2015
2,245
-Did you build it on your breadboard?
-Also do explain to me the logic you folowed and the logic that is now when is working. I do understand something but Im not completly sure I understand it fully.
sarahMCML
Joined May 11, 2019
707
Yes, I did build it, and I have it clocking away quite happily now!
The logic is quite simple, I can't believe it took me so long to realise where I was going wrong!
The only FF which has to change twice during the cycle is "A", so starting with L L, the "1" pulse flips FF "A", and we get "B"=L. A"=H.
Next, the "2" pulse flips FF "B" and we get "B"=H, "A"=H.
Thirdly, the "3" pulse again flips FF "A" back to Low, and we get "B"=H, "A"=L
And finally, the "4" pulse resets everything and starts the cycle over!
Note: I've edited the circuit in post #40 to the correct version!!!!!!!
q12x
Joined Sep 25, 2015
2,245
Yes, you basically explained this:
-But my question was how did you think to add FF's Reset pins to the 4017 MR ? Because I didnt see it in a million years.
-And how did you think to add the OR gates? Pretty genius.
I simplified the cct a bit by removing one OR gate that was doing nothing.
I tested it and is working ok like this:
1714998282699.pnginstead of this:1714998581549.png
Pretty smart for the OR gate usage when the inputs are 0. Practically holding the FF CLK to 0 all the time, until 4017 changes its outputs.
Probably you chased a gate that hold its 0 inputs to a 0 output, and thats how you decided on OR gate to use.
sarahMCML
Joined May 11, 2019
707
View attachment 321755instead of this:View attachment 321757
If you continue successive logic sequences around the loop, without the resetting of the FF's, it becomes apparent that the next sequence becomes:
____A B
"1" 1 1
"2" 1 0
"3" 0 0
And then back to:
____A B
"1" 1 0
"2" 1 1
"3" 0 1
So the correct sequence repeats every other time around the loop. Resetting the FF's avoids this!
And it had to be an OR gate to flip FF "A", since either input "1" OR "3" needs to switch it!
I kept the other OR gate just as a buffer. Not really needed, but as it's there...........
