How to interface SD card with Atmega32, with help of FatFs?
Terror
Joined Dec 22, 2020
15
HI everyone!
First of all: I am using standalone Atmega32 (no arduino or such), Eclipse and C language.
I been troubled with this for a while now, I looked thru lots of forums and sadly couldnt make it work.
Right now my best idea is working on a sample project from http://elm-chan.org/fsw/ff/00index_e.html for avr's.
But any way I came across lots of errors that I couldnt handle.
If anyone could provide some better solution or help me with fixing the code that would be great.
Thank you in advance!
Terror
Joined Dec 22, 2020
15
I know theres lots of stuff on the Internet but none of them answear my problems.
I tried downloading FatFs Sample project for AVR from elm-chans page, but couldnt debug all the errors.
I think I will download one that u posted and let u know how far I can get with it.
jpanhalt
Joined Jan 18, 2008
11,087
I do not do Atmega, C, or SD (yet); however, even if you were using PIC's, Assembly, EEPROM, and SPI (etc), your description is so lacking in information that I could not help you. Basically, the only information you have given is that you want to use an Atmega32, a specific language, and an SD card with a FATFs file system. You have been pointed to various resources, but "none of them work."
That calls for someone who is doing exactly what you are doing, but have not described, to post a solution that you can cut and paste. That is not likely to happen here or anywhere else.
1) You need to show with a diagram what you are trying to do.
2) Show code you have written. Does it compile? Error messages? Simply saying there are error messages doesn't help. You need to show where they occur and what they say.
3) If your code compiles and "doesn't work," what's it doing or failing to do?
In brief, your post #5 suggesting that no one here wants to help you is way off the mark. YOU have not provided any information with which someone knowledgeable about those items can help you.
Terror
Joined Dec 22, 2020
15
It does compile but it fails to display anything into terminal. I tried including files that I used earlier in other projects but they failed 2
MrSalts
Joined Apr 2, 2020
2,767
Iam so sorry, you are right. I just got used to the fact that if I share to much for example project no one would bother to read it and answear.
Here it is:
https://github.com/Werterror/SDCard
Are you saying, the ATMega isn't doing anything? Or what, exactly do you mean by, "fails to display"? Does that mean you can't even get it to program? If so, ...
Which programmer are you using? Which IDE? Which USB-Serial adapter? Do you have the correct USB
Terror
Joined Dec 22, 2020
15
In first post I clarified that Iam using IDE Eclipse. Atmega is programing properly. Other programs run wo issue, simple programs like just UART or even more advanced like reading data from RFID cards.
Problem is with program that I have shared. It seems like it doesnt get to first while loop in main that i supposed to send chars to terminal.
KeithWalker
Joined Jul 10, 2017
3,628
So yea...
Thats why I dont go complex about my questions.
If you don't give enough information, no one can answer your questions.
I don't plan on spending hours going through the code to try to find the problem and I don't plan on making one myself, so it's up to you to do the work.
How are you trying to debug the program? Try sending short messages which include values of important variables to the screen at different points in the program. That will give you some idea of what happening. When you see a bad value or a missing message you will know where to start looking.
Keep us posted. We will help if we can.
Good luck
Terror
Joined Dec 22, 2020
15
So I changed my approach and downloaded one of the sample projects. Tried to run simple UART function to see if at least UART is working. It would complie but nothing would pop on terminal so I deleted all the files but UART and it work. I started adding back files and UART stop working after adding mmc file. So my conclusion is that I my configuration of it iss off. Thats kinda weird cuz I dont even #include that file into main.c just paste it into project. Another thing is that it started to upload way faster than before adding mmc file.
I configure mmc file best to my knowledge but something is probably off, heres mmc file.
C:
/* MMCv3/SDv1/SDv2 Controls via AVR SPI module                           */
/  Copyright (C) 2016, ChaN, all right reserved.
/ * This software is a free software and there is NO WARRANTY.
/ * No restriction on use. You can use, modify and redistribute it for
/   any purpose as you like UNDER YOUR RESPONSIBILITY.
/ * Redistributions of source code must retain the above copyright notice.
#include <avr/io.h>
#include "ff.h"
#include "diskio.h"
#include "mmc_avr.h"
/* Peripheral controls (Platform dependent) */
#define CS_LOW()        PORTB &= ~(1<<PB4)    /* Set MMC_CS = low */
#define    CS_HIGH()        PORTB |= (1<<PB4)    /* Set MMC_CS = high */
//#define MMC_CD            (!(PINB & 0x10))    /* Test if card detected.   yes:true, no:false, default:true */
//#define MMC_WP            (PINB & 0x20)    /* Test if write protected. yes:true, no:false, default:false */
#define    FCLK_SLOW()        (SPCR |= (1<<SPR1))    /* Set SPI clock for initialization (100-400kHz) */
#define    FCLK_FAST()        (SPCR &= (~((1<<SPR0)|(1<<SPR1) )))    /* Set SPI clock for read/write (20MHz max) */
   Module Private Functions
/* Definitions for MMC/SDC command */
#define CMD0    (0)            /* GO_IDLE_STATE */
#define CMD1    (1)            /* SEND_OP_COND (MMC) */
#define    ACMD41    (0x80+41)    /* SEND_OP_COND (SDC) */
#define CMD8    (8)            /* SEND_IF_COND */
#define CMD9    (9)            /* SEND_CSD */
#define CMD10    (10)        /* SEND_CID */
#define CMD12    (12)        /* STOP_TRANSMISSION */
#define ACMD13    (0x80+13)    /* SD_STATUS (SDC) */
#define CMD16    (16)        /* SET_BLOCKLEN */
#define CMD17    (17)        /* READ_SINGLE_BLOCK */
#define CMD18    (18)        /* READ_MULTIPLE_BLOCK */
#define CMD23    (23)        /* SET_BLOCK_COUNT (MMC) */
#define    ACMD23    (0x80+23)    /* SET_WR_BLK_ERASE_COUNT (SDC) */
#define CMD24    (24)        /* WRITE_BLOCK */
#define CMD25    (25)        /* WRITE_MULTIPLE_BLOCK */
#define CMD32    (32)        /* ERASE_ER_BLK_START */
#define CMD33    (33)        /* ERASE_ER_BLK_END */
#define CMD38    (38)        /* ERASE */
#define    CMD48    (48)        /* READ_EXTR_SINGLE */
#define    CMD49    (49)        /* WRITE_EXTR_SINGLE */
#define CMD55    (55)        /* APP_CMD */
#define CMD58    (58)        /* READ_OCR */
static volatile
DSTATUS Stat = STA_NOINIT;    /* Disk status */
static volatile
BYTE Timer1, Timer2;    /* 100Hz decrement timer */
static
BYTE CardType;            /* Card type flags (b0:MMC, b1:SDv1, b2:SDv2, b3:Block addressing) */
/* Power Control  (Platform dependent)                                   */
/* When the target system does not support socket power control, there   */
/* is nothing to do in these functions and chk_power always returns 1.   */
static
void power_on (void)
    /* Configure MOSI/MISO/SCLK/CS pins */
    PORTB |= 0b00110000;    /* Configure SCK/MOSI/CS as output */
    DDRB  |= 0b10110000;
    SPCR = 0x52;            /* Enable SPI function in mode 0 */
    SPSR = 0x01;
static
void power_off (void)
    SPCR = 0;                /* Disable SPI function */
    DDRB  &= ~10110000;    /* Set SCK/MOSI/CS as hi-z, INS#/WP as pull-up */
    PORTB &= ~10110000;
    PORTB |=  0b00000000;
    /* De-configure MOSI/MISO/SCLK/CS pins (set hi-z) */
    //DDRB &= ~0b00110111;
    //PORTB &= ~0b00000111;
    //PORTB |= 0b00110000;
    /* Trun socket power off (nothing to do if no power controls) */
    //To be filled
/* Transmit/Receive data from/to MMC via SPI  (Platform dependent)       */
/* Exchange a byte */
static
BYTE xchg_spi (        /* Returns received data */
    BYTE dat        /* Data to be sent */
    SPDR = dat;
    loop_until_bit_is_set(SPSR, SPIF);
    return SPDR;
/* Receive a data block fast */
static
void rcvr_spi_multi (
    BYTE *p,    /* Data read buffer */
    UINT cnt    /* Size of data block */
    do {
        SPDR = 0xFF;
        *p++ = SPDR;
        SPDR = 0xFF;
        *p++ = SPDR;
    } while (cnt -= 2);
/* Send a data block fast */
static
void xmit_spi_multi (
    const BYTE *p,    /* Data block to be sent */
    do {
        SPDR = *p++;
        SPDR = *p++;
    } while (cnt -= 2);
/* Wait for card ready                                                   */
static
int wait_ready (    /* 1:Ready, 0:Timeout */
    UINT wt            /* Timeout [ms] */
    BYTE d;
    Timer2 = wt / 10;
    do
        d = xchg_spi(0xFF);
        /* This loop takes a time. Insert rot_rdq() here for multitask envilonment. */
    while (d != 0xFF && Timer2);
    return (d == 0xFF) ? 1 : 0;
/* Deselect the card and release SPI bus                                 */
static
void deselect (void)
    CS_HIGH();        /* Set CS# high */
    xchg_spi(0xFF);    /* Dummy clock (force DO hi-z for multiple slave SPI) */
/* Select the card and wait for ready                                    */
static
int select (void)    /* 1:Successful, 0:Timeout */
    CS_LOW();        /* Set CS# low */
    xchg_spi(0xFF);    /* Dummy clock (force DO enabled) */
    if (wait_ready(500)) return 1;    /* Leading busy check: Wait for card ready */
    deselect();        /* Timeout */
    return 0;
/* Receive a data packet from MMC                                        */
static
int rcvr_datablock (
    BYTE *buff,            /* Data buffer to store received data */
    UINT btr            /* Byte count (must be multiple of 4) */
    BYTE token;
    Timer1 = 20;
    do {                            /* Wait for data packet in timeout of 200ms */
        token = xchg_spi(0xFF);
    } while ((token == 0xFF) && Timer1);
    if (token != 0xFE) return 0;    /* If not valid data token, retutn with error */
    rcvr_spi_multi(buff, btr);        /* Receive the data block into buffer */
    xchg_spi(0xFF);                    /* Discard CRC */
    xchg_spi(0xFF);
    return 1;                        /* Return with success */
/* Send a data packet to MMC                                             */
#if    _USE_WRITE
static
int xmit_datablock (
    const BYTE *buff,    /* 512 byte data block to be transmitted */
    BYTE token            /* Data/Stop token */
    BYTE resp;
    if (!wait_ready(500)) return 0;        /* Leading busy check: Wait for card ready to accept data block */
    xchg_spi(token);                    /* Xmit data token */
    if (token == 0xFD) return 1;        /* Do not send data if token is StopTran */
    xmit_spi_multi(buff, 512);            /* Data */
    xchg_spi(0xFF); xchg_spi(0xFF);        /* Dummy CRC */
    resp = xchg_spi(0xFF);                /* Receive data resp */
    return (resp & 0x1F) == 0x05 ? 1 : 0;    /* Data was accepted or not */
    /* Busy check is done at next transmission */
#endif
/* Send a command packet to MMC                                          */
static
BYTE send_cmd (        /* Returns R1 resp (bit7==1:Send failed) */
    BYTE cmd,        /* Command index */
    DWORD arg        /* Argument */
    BYTE n, res;
    if (cmd & 0x80) {    /* ACMD<n> is the command sequense of CMD55-CMD<n> */
        cmd &= 0x7F;
        res = send_cmd(CMD55, 0);
        if (res > 1) return res;
    /* Select the card and wait for ready except to stop multiple block read */
    if (cmd != CMD12) {
        deselect();
        if (!select()) return 0xFF;
    /* Send command packet */
    xchg_spi(0x40 | cmd);                /* Start + Command index */
    xchg_spi((BYTE)(arg >> 24));        /* Argument[31..24] */
    xchg_spi((BYTE)(arg >> 16));        /* Argument[23..16] */
    xchg_spi((BYTE)(arg >> 8));            /* Argument[15..8] */
    xchg_spi((BYTE)arg);                /* Argument[7..0] */
    n = 0x01;                            /* Dummy CRC + Stop */
    if (cmd == CMD0) n = 0x95;            /* Valid CRC for CMD0(0) + Stop */
    if (cmd == CMD8) n = 0x87;            /* Valid CRC for CMD8(0x1AA) Stop */
    xchg_spi(n);
    /* Receive command response */
    if (cmd == CMD12) xchg_spi(0xFF);        /* Skip a stuff byte when stop reading */
    n = 10;                                /* Wait for a valid response in timeout of 10 attempts */
    do
        res = xchg_spi(0xFF);
    while ((res & 0x80) && --n);
    return res;            /* Return with the response value */
   Public Functions
/* Initialize Disk Drive                                                 */
DSTATUS mmc_disk_initialize (void)
    BYTE n, cmd, ty, ocr[4];
    power_off();                        /* Turn off the socket power to reset the card */
    for (Timer1 = 10; Timer1; ) ;        /* Wait for 100ms */
    if (Stat & STA_NODISK) return Stat;    /* No card in the socket? */
    power_on();                            /* Turn on the socket power */
    FCLK_SLOW();
    for (n = 10; n; n--) xchg_spi(0xFF);    /* 80 dummy clocks */
    ty = 0;
    if (send_cmd(CMD0, 0) == 1) {            /* Put the card SPI mode */
        Timer1 = 100;                        /* Initialization timeout of 1000 msec */
        if (send_cmd(CMD8, 0x1AA) == 1) {    /* Is the card SDv2? */
            for (n = 0; n < 4; n++) ocr[n] = xchg_spi(0xFF);    /* Get trailing return value of R7 resp */
            if (ocr[2] == 0x01 && ocr[3] == 0xAA) {                /* The card can work at vdd range of 2.7-3.6V */
                while (Timer1 && send_cmd(ACMD41, 1UL << 30));    /* Wait for leaving idle state (ACMD41 with HCS bit) */
                if (Timer1 && send_cmd(CMD58, 0) == 0) {        /* Check CCS bit in the OCR */
                    ty = (ocr[0] & 0x40) ? CT_SD2 | CT_BLOCK : CT_SD2;    /* Check if the card is SDv2 */
        } else {                            /* SDv1 or MMCv3 */
            if (send_cmd(ACMD41, 0) <= 1)     {
                ty = CT_SD1; cmd = ACMD41;    /* SDv1 */
            } else {
                ty = CT_MMC; cmd = CMD1;    /* MMCv3 */
            while (Timer1 && send_cmd(cmd, 0));            /* Wait for leaving idle state */
            if (!Timer1 || send_cmd(CMD16, 512) != 0)    /* Set R/W block length to 512 */
                ty = 0;
    CardType = ty;
    deselect();
    if (ty) {            /* Initialization succeded */
        Stat &= ~STA_NOINIT;        /* Clear STA_NOINIT */
        FCLK_FAST();
    } else {            /* Initialization failed */
        power_off();
    return Stat;
/* Get Disk Status                                                       */
DSTATUS mmc_disk_status (void)
    return Stat;
/* Read Sector(s)                                                        */
DRESULT mmc_disk_read (
    BYTE *buff,            /* Pointer to the data buffer to store read data */
    DWORD sector,        /* Start sector number (LBA) */
    UINT count            /* Sector count (1..128) */
    BYTE cmd;
    if (!count) return RES_PARERR;
    if (Stat & STA_NOINIT) return RES_NOTRDY;
    if (!(CardType & CT_BLOCK)) sector *= 512;    /* Convert to byte address if needed */
    cmd = count > 1 ? CMD18 : CMD17;            /*  READ_MULTIPLE_BLOCK : READ_SINGLE_BLOCK */
    if (send_cmd(cmd, sector) == 0) {
        do {
            if (!rcvr_datablock(buff, 512)) break;
            buff += 512;
        } while (--count);
        if (cmd == CMD18) send_cmd(CMD12, 0);    /* STOP_TRANSMISSION */
    deselect();
    return count ? RES_ERROR : RES_OK;
/* Write Sector(s)                                                       */
#if _USE_WRITE
DRESULT mmc_disk_write (
    const BYTE *buff,    /* Pointer to the data to be written */
    if (Stat & STA_PROTECT) return RES_WRPRT;
    if (count == 1) {    /* Single block write */
        if ((send_cmd(CMD24, sector) == 0)    /* WRITE_BLOCK */
            && xmit_datablock(buff, 0xFE)) {
            count = 0;
    else {                /* Multiple block write */
        if (CardType & CT_SDC) send_cmd(ACMD23, count);
        if (send_cmd(CMD25, sector) == 0) {    /* WRITE_MULTIPLE_BLOCK */
            do {
                if (!xmit_datablock(buff, 0xFC)) break;
                buff += 512;
            } while (--count);
            if (!xmit_datablock(0, 0xFD)) count = 1;    /* STOP_TRAN token */
    deselect();
#endif
/* Miscellaneous Functions                                               */
#if _USE_IOCTL
DRESULT mmc_disk_ioctl (
    BYTE cmd,        /* Control code */
    void *buff        /* Buffer to send/receive control data */
    DRESULT res;
    BYTE n, csd[16], *ptr = buff;
    DWORD *dp, st, ed, csize;
#if _USE_ISDIO
    SDIO_CTRL *sdi;
    BYTE rc, *bp;
    UINT dc;
#endif
    res = RES_ERROR;
    switch (cmd) {
    case CTRL_SYNC :        /* Make sure that no pending write process. Do not remove this or written sector might not left updated. */
        if (select()) res = RES_OK;
        deselect();
        break;
    case GET_SECTOR_COUNT :    /* Get number of sectors on the disk (DWORD) */
        if ((send_cmd(CMD9, 0) == 0) && rcvr_datablock(csd, 16)) {
            if ((csd[0] >> 6) == 1) {    /* SDC ver 2.00 */
                csize = csd[9] + ((WORD)csd[8] << 8) + ((DWORD)(csd[7] & 63) << 16) + 1;
                *(DWORD*)buff = csize << 10;
            } else {                    /* SDC ver 1.XX or MMC*/
                n = (csd[5] & 15) + ((csd[10] & 128) >> 7) + ((csd[9] & 3) << 1) + 2;
                csize = (csd[8] >> 6) + ((WORD)csd[7] << 2) + ((WORD)(csd[6] & 3) << 10) + 1;
                *(DWORD*)buff = csize << (n - 9);
            res = RES_OK;
        deselect();
        break;
    case GET_BLOCK_SIZE :    /* Get erase block size in unit of sector (DWORD) */
        if (CardType & CT_SD2) {    /* SDv2? */
            if (send_cmd(ACMD13, 0) == 0) {    /* Read SD status */
                xchg_spi(0xFF);
                if (rcvr_datablock(csd, 16)) {                /* Read partial block */
                    for (n = 64 - 16; n; n--) xchg_spi(0xFF);    /* Purge trailing data */
                    *(DWORD*)buff = 16UL << (csd[10] >> 4);
                    res = RES_OK;
            if ((send_cmd(CMD9, 0) == 0) && rcvr_datablock(csd, 16)) {    /* Read CSD */
                if (CardType & CT_SD1) {    /* SDv1 */
                    *(DWORD*)buff = (((csd[10] & 63) << 1) + ((WORD)(csd[11] & 128) >> 7) + 1) << ((csd[13] >> 6) - 1);
                } else {                    /* MMCv3 */
                    *(DWORD*)buff = ((WORD)((csd[10] & 124) >> 2) + 1) * (((csd[11] & 3) << 3) + ((csd[11] & 224) >> 5) + 1);
                res = RES_OK;
        deselect();
        break;
    case CTRL_TRIM:        /* Erase a block of sectors (used when _USE_TRIM in ffconf.h is 1) */
        if (!(CardType & CT_SDC)) break;                /* Check if the card is SDC */
        if (mmc_disk_ioctl(MMC_GET_CSD, csd)) break;    /* Get CSD */
        if (!(csd[0] >> 6) && !(csd[10] & 0x40)) break;    /* Check if sector erase can be applied to the card */
        dp = buff; st = dp[0]; ed = dp[1];                /* Load sector block */
        if (!(CardType & CT_BLOCK)) {
            st *= 512; ed *= 512;
        if (send_cmd(CMD32, st) == 0 && send_cmd(CMD33, ed) == 0 && send_cmd(CMD38, 0) == 0 && wait_ready(30000)) {    /* Erase sector block */
            res = RES_OK;    /* FatFs does not check result of this command */
        break;
    /* Following commands are never used by FatFs module */
    case MMC_GET_TYPE :        /* Get card type flags (1 byte) */
        *ptr = CardType;
        res = RES_OK;
        break;
    case MMC_GET_CSD :        /* Receive CSD as a data block (16 bytes) */
        if (send_cmd(CMD9, 0) == 0 && rcvr_datablock(ptr, 16)) {    /* READ_CSD */
            res = RES_OK;
        deselect();
        break;
    case MMC_GET_CID :        /* Receive CID as a data block (16 bytes) */
        if (send_cmd(CMD10, 0) == 0 && rcvr_datablock(ptr, 16)) {    /* READ_CID */
            res = RES_OK;
        deselect();
        break;
    case MMC_GET_OCR :        /* Receive OCR as an R3 resp (4 bytes) */
        if (send_cmd(CMD58, 0) == 0) {    /* READ_OCR */
            for (n = 4; n; n--) *ptr++ = xchg_spi(0xFF);
            res = RES_OK;
        deselect();
        break;
    case MMC_GET_SDSTAT :    /* Receive SD statsu as a data block (64 bytes) */
        if (send_cmd(ACMD13, 0) == 0) {    /* SD_STATUS */
            xchg_spi(0xFF);
            if (rcvr_datablock(ptr, 64)) res = RES_OK;
        deselect();
        break;
    case CTRL_POWER_OFF :    /* Power off */
        power_off();
        Stat |= STA_NOINIT;
        res = RES_OK;
        break;
#if _USE_ISDIO
    case ISDIO_READ:
        sdi = buff;
        if (send_cmd(CMD48, 0x80000000 | (DWORD)sdi->func << 28 | (DWORD)sdi->addr << 9 | ((sdi->ndata - 1) & 0x1FF)) == 0) {
            for (Timer1 = 100; (rc = xchg_spi(0xFF)) == 0xFF && Timer1; ) ;
            if (rc == 0xFE) {
                for (bp = sdi->data, dc = sdi->ndata; dc; dc--) *bp++ = xchg_spi(0xFF);
                for (dc = 514 - sdi->ndata; dc; dc--) xchg_spi(0xFF);
                res = RES_OK;
        deselect();
        break;
    case ISDIO_WRITE:
        sdi = buff;
        if (send_cmd(CMD49, 0x80000000 | (DWORD)sdi->func << 28 | (DWORD)sdi->addr << 9 | ((sdi->ndata - 1) & 0x1FF)) == 0) {
            xchg_spi(0xFF); xchg_spi(0xFE);
            for (bp = sdi->data, dc = sdi->ndata; dc; dc--) xchg_spi(*bp++);
            if ((xchg_spi(0xFF) & 0x1F) == 0x05) res = RES_OK;
        deselect();
        break;
    case ISDIO_MRITE:
        sdi = buff;
        if (send_cmd(CMD49, 0x84000000 | (DWORD)sdi->func << 28 | (DWORD)sdi->addr << 9 | sdi->ndata >> 8) == 0) {
            xchg_spi(sdi->ndata);
            for (dc = 513; dc; dc--) xchg_spi(0xFF);
        deselect();
        break;
#endif
    default:
        res = RES_PARERR;
    return res;
#endif
KeithWalker
Joined Jul 10, 2017
3,628
The mmc file is probably accessing resources used by other libraries in the program, causing a conflict. Can you find a different way or another library to do it?
