dear eric,Morning rajit,
What is the voltage value you have available for the negative supply.?
E
dear eric,hi,
This is one option using a -5V supply for the OPA's.
My only concern is that we are at the limits of the maximum power supply of the LM358, we have +24v and -5v == 29V total.
The LM358 is specified at 30V.
For the demo plot attached I have made the bridge voltage start at -0.1mV thru +3.6mV in order to show the Vout can be set to above or below zero, by using R18 trim pot.
Note: the 2N3819 is reconnected for the 4mA threshold.
E
okay eric. i will check with ithi rajit,
You could consider a 15Vdc to 5Vdc Isolated DC2DC converter for -5V.
E
EDIT:
Example
https://www.reichelt.com/gb/en/?LAN...4tbrNlD67epn9oRONJQpL-bhkGHug0RoCf7UQAvD_BwE&
