how to get negative output pulse from 555 timer in monostable state
T Thread Starter TAKYMOUNIR Joined Jun 23, 2008 352 Dec 7, 2011 #1 how to get negative output pulse from 555 timer in monostable state
praondevou Joined Jul 9, 2011 2,942 Dec 7, 2011 #2 From a simple 555 monostable you can't get a negative output. Do you mind telling us what you want to achieve? What is the negative pulse for, what's the pulse width and voltage?
MrChips Joined Oct 2, 2009 35,145 Dec 8, 2011 #3 You can get a negative pulse but it would be best for you to elaborate on what you are trying to do.
t_n_k Joined Mar 6, 2009 5,455 Dec 8, 2011 #4 This is one way in which it could be done. Attachments 555 Timer Astable with negative output pulses.png 4.9 KB Views: 206
t06afre Joined May 11, 2009 5,934 Dec 8, 2011 #5 Hi do you mean negated output. Negated means short explained that then the "output" is supposed to be in high state it is in low state and vice versa.
