I am using 6n137 opto-coupler to take engine tachometer 12v signal from ECU, then send it to arduino nano esp32 that in return it drives rev RGB LEDs. I found in the optocoupler data sheet that the minimum input voltage is 4.5V at Vcc. Is it ok if i supply Vcc with 5V and pull up Vo to 3.3V from the arduino, to get 3.3V pulse output? as shown in below figure.
