How to design a multistage discrete BJT amplifier
Status
Not open for further replies.
35,161
Should I split the gain between all three stages or just the first two? What would you recommend?
A gain of 10 in the first stage and 5 in the second will give you a total gain of 50.
The function of the output stage should be to provide power into the load with a voltage gain of 1.
35,161
Typically, a transistor might have a beta of 100 to 300.
We don’t design a single stage amplifier with that much gain. Instead, we use negative feedback which provides many advantages.
A circuit gain of 10 to 25 is very adequate for your application.
ericgibbs
Joined Jan 29, 2010
21,567
Hi MC,
The TS has been given a Gain figure of 50V/V ie: 50, using a 3 stage BJT amp.
The midband gain of the amplifier shall be 50 V/V
E
ericgibbs
Joined Jan 29, 2010
21,567
Hi MC.
That's the gain/stage ratio's I am trying to get the TS to design.
The specified BW is limited to 20Hz /18kHz.
No Input or output impedances specified.
E
GF Oberholzer
Joined May 23, 2023
39
The last stage has to be a pnp according to the specifications so this is the design I came up with for a gain of 50.
I now need to get the correct bandwidth freqeuncy. Is that only dependent on the capacitors ?
35,161
Think positive current flow.
The arrow on the emitter shows the direction current will flow in a properly biased transistor.
ericgibbs
Joined Jan 29, 2010
21,567
Hi F,
It helps if you post your versions of the circuit LTSpice asc file.
Do you know how create to the AC analysis plots for the BW.?
E
ericgibbs
Joined Jan 29, 2010
21,567
Hi GF,
Change the .tran to this image, add the 1V AC to the V1 source details.
Add a Node label as Vin and one for Vout, using the F4 key.
Ask if you have a problem.
E
Status
