How to connect E3JM-R4S4 PNP Sensor
toby159
Joined Apr 29, 2020
Hi, this is E3JM-R4S4, brown and blue connect to power supply. I wanted to know is it either black or brown connect to +load and the white connect to 0V?
If is it so, I don't see the electric flow.
toby159
Joined Apr 29, 2020
Welcome to AAC!
Black connects to -load, white to ground, brown connection depends on the power source.
You mean grey connect to +24V, white connect to 0V and the black connect to load like PLC?
The black is negative signal right?
