how to amplify 20 to 50mV upto 5V?
NehaSharmaa
Joined Mar 18, 2021
hi I'm using pressure sensor MPX10DP its output voltage is ranging from 20mV to 50mV... for arduino i want output voltage upto 5V what should i do? is there any amplifier module available ? or i have to make it myself ? also can u plz give the specific ic number ?
Ya’akov
Joined Jan 27, 2019
10,281
The sort of thing you are looking for is called an instrumentation amplifier. You can read about them online, but with a little more information, as @ericgibbs said, people will be happy to help you with circuits.
ericgibbs
Joined Jan 29, 2010
21,541
hi Neha,
This is a 'typical' example of a simple voltage level shifting circuit
Input 20mV thru 50mV... Output 'close' to 0v thru +5Vmax.
Uses a rail to rail amplifier, with a 6Vdc supply.
If you decide to self build we can finalise the circuit to suit your components.
E
BobTPH
Joined Jun 5, 2013
11,619
The opamp you show has an input offset of up to 3mV. That will not be very accurate with a 20mV input I think an instrumentation amp or at least a low offset amp is needed.
Bob
sghioto
Joined Dec 31, 2017
8,744
If you use a simple amplifier with a gain of 100 you will have a 2 to 5 volt output.
It's unclear to me if you want 20mv to equal 0 volts and 50 mv to equal 5 volts. Is this your intention?
