How to build powerful amplify
Don_Fila
Joined Nov 26, 2021
172
How to build powerful mini amplify that uses bluetooth with USB model which can work with big speakers systems and can create distortion.
Danko
Joined Nov 22, 2017
2,236
Price of this amplifier is $ 27.99
S-299 4*400W 4.1CH Mini Power Amplifier Audio Karaoke
Home Theater Amplifiers Home Car Bluetooth Wireless Amplifier USB/SD AUX
LowQCab
Joined Nov 6, 2012
5,102
These normally come with a Switching-Power-Supply capable of less than ~100-Watts,
( but usually closer to ~60-Watts or even less ).
Here is a ~125-Watts per channel Amp that can actually smoke some Speakers permanently.
If You really want some Distortion,
I suggest that You create that Distortion with a Guitar-Effects-Pedal first,
then send that Distorted-Signal to the Amplifier.
Don't over-drive the Amplifier, unless it's a Tube-Amp that is designed for that type of abuse.
28,276
There are MANY audio power amplifier circuits on the "Schematicsforfree" website, and no malware or obnoxious advertising.
There is also a section of guitar effects circuits, which includes distortion.
I find that 1600 watt amplifier shown in post #3 to be rather difficult to accept as being a legitimate product and not a simple fraud.
LowQCab
Joined Nov 6, 2012
5,102
The 1600-Watt Amp is simply following the standard
Chinese-Power-Rating method of adding 2 or more zeros to the end of the Rated-Power-figure.
It really will produce 1600-Watts of heat if You hit with a big enough Laser-Beam, no really, I'm not kidding !!!
28,276
Question!! Which 1600 watt power amp is LQC referencing in post #6???If it is the one shown in the ad in post #3, that might be the max IPP rating. (IPP= Instant Peak Power.) That is, the maximum power the can be delivered for one cycle. With whatever level of drive needed to produce it.
LowQCab
Joined Nov 6, 2012
5,102
That's right when all the Power-Transistors go ......... "PAK".........
and the Blue-Smoke comes out all over the place !!!!
28,276
Any actual amplifier that can actually deliver 1600 watts of audio power will not be a " powerful mini amplify that uses bluetooth with USB model" unless it is nearly 100% efficient. The problem then will be distortion in excess of what the TS is probably planning on having.
