How should I stop 7 segment for counting? It should be only be counting 0-8.
33,203
no i dont. I am the one whos doing my works. Its not bad to ask what you dont know, right? I just cant express what i want to say thats why my words are lacking.. I dont have any idea about this because my major is about Computer Hardware/software.. Our professor are not food spooning thats why I cant understand what I must understand.
So you think that it is your professor's role to spoon feed you everything?
If your major is about computer hardware, then there is no excuse for not having any idea about this since computer hardware is this stuff on mega-steroids. You REALLY need to get the basic fundamentals down. Until you do you will not only continue to struggle, but your struggles will only get worse and worse.
33,203
The CKB of 74ls90?
How can the CKB pin, which is an INPUT, tell you anything.
Go back to the data sheet and first focus on what the two clock signals (CKA and CKB) do. If you can explain why the data sheet tells you to connect QA to CKB to get a full-length count, that will be a major step forward in your level of understanding of this IC.
33,203
Go look them up on your diagram and compare the two schematics. The CKB signal you have been referring to is "INPUT B" in that diagram.
Tomomi Mei Manalili Reyes
Joined Feb 3, 2016
49
Sorry, I stated wrong statement earlier.. i thought the pins(number of pins that was in parenthesis) are the counts... thats why i conclude that at 9 pin, the connections must be stop.. Sorry,.
