How mixer works
Man10
Joined Jul 31, 2018
205
If L is a local oscillator signal and F is a radio frequency input signal, then the output of a mixer is F - L, F + L and other frequencies, if L and F are inputs to the mixer?
Man10
Joined Jul 31, 2018
205
I have been researching radio engineering. I am just trying to understand what I read. The output of the mixer consist of multiple frequencies.
BobTPH
Joined Jun 5, 2013
11,666
Correct. The name mixer is a bit misleading though, it sounds like the two inputs are added, when actually, they must be multiplied.
Bob
BobTPH
Joined Jun 5, 2013
11,666
The modulation does not change what the mixer does, to a first approximation, and it is preserved by the mixer, modulating the additional frequencies.
Bob
Man10
Joined Jul 31, 2018
205
So if i use a mixer to downconvert a higher frequency to a lower frequency, the mixer will produce harmonics and i should use a bandpass filter to filter harmonics to separate desired signal from harmonics?
Papabravo
Joined Feb 24, 2006
22,115
So a mixer produces harmonics and 1 of these harmonics equals local oscillator frequency + radio frequency input?
What is produced by a "mixer" with the LO frequency l, below the signal frequency f
  1. A signal at the LO frequency l
  2. A signal at the input frequency f
  3. An output at the frequency (f + l), called the Upper Sideband (USB)
  4. An output at the frequency (f - l), called the Lower Sideband (LSB)
The behavior is the result of the multiplication of two sine waves. If you remember your Trigonometry you can work this out for yourself. This is a non-linear operation which is used to produce signals at new frequencies that are different than the frequencies of either input. It is worth noting that both sidebands contain the same information.
