How to bypass balance pot on audio mixer
BobTPH
Joined Jun 5, 2013
11,647
I think what you are calling the balance pot is what directs each input to the two outputs. That is the main function of the mixer. Taking them out does not make it do anything it cannot do with them.
What is it you are try to accomplish? Where should the signals go without the pot?
Jukebox Swirls
Joined Apr 27, 2024
11
This is the balance pot. The gain pot is on a board below this but I understand if it’s not possible. I want to remove the balance pot on each channel for a cleaner signal. This is what the mixer looks like. It’s a copy of a UREI 1620 but not the same inside.IMG_8901.jpeg
Ian0
Joined Aug 7, 2020
13,278
Balance pots are usually wired with the ends of the track to the Left and Right signals, and the wiper to ground.
If so, you can simply remove it. It will work without it.
if the signal is not clean, it won't be any cleaner without the balance pot, unless your balance pots are worn out.
Ian0
Joined Aug 7, 2020
13,278
Generally wired like this:
Screenshot from 2025-10-23 18-56-33.pngSo, just remove it. No need to replace it by anything. If you do, all you get is an attenuator of about 3dB.
Jukebox Swirls
Joined Apr 27, 2024
11
Unfortunately, removing the pot produced no audio.
I will try the fixed resistors route since a pot is a variable resistor (duh I’m slow)
It’s a 10k pot. How would I wire in the two 5k (fixed) resistors. And do I jumper something? I guess I can just experiment. Thanks
bertus
Joined Apr 5, 2008
23,005
The two resistor method replacing the pot:
One resistor from one end to the centerpin of the pot, the other resistor from the centerpin to the other end of the pot.
Bertus
Ian0
Joined Aug 7, 2020
13,278
Is it a mono or a stereo pot? (how many pins?)
