- Joined Jan 23, 2018
- 28,312
An open diode will result in a complete loss of the dynamic braking function, a shorted diode will result in the voltage that the string begins drawing current being reduced by one diode drop voltage.turning turbine is an option maybe once a year, once for 2 years when there is catastrophic wind occurs. in such a case there will be meteorology warnings and i can give the turbine simply down, which will be the only 100% safe solution...
so back to diode string solution. what happens if 1 of those 38 diodes fails? how failed diode performs, as open or closed circuit?
another question, how to cool diodes? some contact passive cooler is possible? to avoid noise from fans...
And certainly the diodes will have to be attached to a heat sink able to dissipate all of that power without having an excessive temperature rise. And at full output that will be quite a few watts. 30 amps at 28 volts will be 790 watts, as much as a small electric space heater. So the diodes package could be up on the mast in that wind stream.
So how about a fold over hinge on the mast, since excess wind speed will cause more force against the turbine than normal wind speeds? A well constructed mechanical fold-back system would be able to protect against the much stronger winds.
