Hello all,
I am planning to install 2 footwell led lights into my car.
The idea is to have the white footwell serves as welcome light that goes on and off with the interior lighting, and the RGB footwell has the same function but there is an additional switch on the driver side panel to wire it up with constant ground such that I can keep it on while driving if needed.
The design shown above may be problematic as I believe all interior lights and the white footwell would also turn on when the switch is closed.
My thought to solve this is to put a diode between the RGB footwell and the M14 Red wire such that current cannot flow from the Red wire to the switched ground.
I only have basic electronic knowledge from high school so I am not sure if that will work if a diode is placed on the ground section. Don't wanna try it on my car to avoid causing any problem to the BCM.
Could someone please help and advise?
