I'm not convinced that you have thought this through or that you even understand the problemif you could let me know if there is reference to build circuit do that
first thank you for your reply
about first point i want to use GPS if the distance is too far for both of them to find each other but if they are in same range the slave have to follow the leader always
you are exactly correctWhat is your background and experience in electronics? Based on the question, I am assuming it is low. In other words, you don't yet know how much you don't know. You are asking to do something that is very difficult.
GPS receivers w/ antennas at 2M resolution
GPS to microcontroller communication (
Wireless communication between devices (undetermined amount of data, data communication protocol, communication rate, ...)
Onboard calculations of x/y/z deltas
Onboard calculations of x/y/z adjustments to position (distance, acceleration, deceleration, error, rate of change in error, ...)
Power to all units
Interference and datacomm quality / error handling
Unless you are aware of all plug-and-play modules, then go for it. If you are building/programming yourself, then let us know where you stand with skill level so we can adjust our comments as needed.
No in fact i can make it fly also i can control it very good i think i have good experience in that also i decide to add small computer running with Linux i can work perfect on Linux also soIn terms of your design, what have you got so far?
If you really don't know where to start and you have nothing then this is not for you because you are essentially asking how to do everything i.e. initial concept and specification, problem solving, mechanical hardware design, electronic hardware design, software design, hardware construction, prototyping, troubleshooting etc, etc......
And how much time do you think you will spend developing this on your own.. WAY... more then $1k USD worth..i found something like i want to made but its expensive around 1k USD
Another vapor-ware product.i found something like i want to made but its expensive around 1k USD
http://blogs.discovermagazine.com/d...selfie-snapping-drone-assistant/#.VeSC-K22pXw
but its not the same project but its too close
Regards
Lily Robotics says its decision on Thursday to shut down and return pre-order payments for a never-delivered drone, which came on the same day that San Francisco District Attorney George Gascón charged the company with false advertising and misleading business practices, was purely coincidental.
The complaint against Lily, obtained by The Register, alleges that the company knowingly misled customers by creating a promotional video that purported to show video footage captured with a Lily drone prototype.
"In fact, none of the video in the Promotional Video was shot by a Lily Camera," the complaint says. "Most notably, the POV footage used in the promotional video was filmed using a professional camera drone called the DJI Inspire."
Pay the $1K. This would be a challenging project for an experienced engineer. You could spend big dollars and get nowhere after many months of work. If you can buy a solution, do it.hello
i have 2 devices i need one of this devices follow the other one where it is going to stay close around 2 Meters
and if its far away its send coordinates where it is throw GPS service
any help from where i can start?
