This is a AVR circuit ive reverse engineered & rebuilt which was faulty on a generator. It may be of some help.
Jumped into this thread couple days ago. Good one. Very helpful.Hi Stew,
If the Generator failure mode was no output (0V rms) then the shorted diode is likely D7 (1N4006) otherwise its likely D6 (1N4006), if it failed with max output (142Vrms). How did it fail? My schematic has an error... D6 and D7 should be swapped.
LTspice doesn't do PCB layout. There are free layout tools online... google: PCB layout.
I got my gen to run today. Lots of air is drawn in around the PCB and seems to exit at the other end of the gen near the engine... this is good.
The BU93T (Q3) is a tuff transistor and is designed to run hot and to work in this kind of application. I'am anguish to here if it tests okay. It is a darlington (b-e resistors built-in) so it may not test with a simple meter. You can use a 9V batt in series with a resistor (lamp?) across the emitter-collector, then drive the base-emitter with a 5K res from +9V to base... lamp should turn on.
Do all the generators have burned PCBs? Could the heat have caused Q3's pin soldering to melt and open?
Regards,
Wayne
Hellohi,
I'm doing a similar project.. i have to design an AVR for a single phase alternator(220v, <10 KVA).The existing AVRs have a feature of underfrequency shut down... i.e. below a specified frequency, which can be adjusted by a potentiometer...
Kindly suggest me a frequecy to voltage converter IC which is low in cost..
Hello
I miss the electronic diagram of a Automatic Voltage Regulator AVR 0-110 V
it is used to excite the rotor generators
sadekmar86@yahoo.fr
Is what you can help me please
