nuwan prasanna 1234
- Joined Nov 29, 2014
- 2
I got it to work If anyone needs a good look at those 5 color band resistors I can email them to you. I am working on hand drawing the PCB with the print over it.
Is google so hard to use?Plz
Sent me resister colour code
7 years after your post, i wanna ask you some explanations about your circuit plz.This is a AVR circuit ive reverse engineered & rebuilt which was faulty on a generator. It may be of some help.
Sir How much voltage shoud i expect on the base of bjt?Oh, I forgot about the R2 (10K) - C2 (3nF) circuit. It introduce some sort of hysteresis to the Mosfet gate control signal.
When the Mosfet is conducting (ON state), the voltage across C2 is kept to 0V (the Mosfet drain is almost at the ground level). When BJT starts conducting, the Mosfet is turned OFF thus its drain voltage rises to 90VDC + 0.7VDC (D1). At this point, we have another voltage divider (R2 - R4) which are keeping the BJT in conduction mode (hence keeping the Mosfet in OFF state) even if the feedback voltage is bellow 6.2V + 0.7V.
Now C2 will start to charge through R2 to the point when the R2-R4 voltage divider will no longer keep the BJT biased.
When the Mosfet is turning ON again (due to feedback voltage), its drain falls to ground hence the BJT is further turned off by the "reversed" voltage divider (R4 - R2) and the voltage across C2.
That's it, the R2-C2 time constant is very important for a proper circuit operation.
Mosfet on diagramme irfs640 IS rated for 200v vds and about 30v vgsBtw, a Vds rating of 100V for the Mosfet is much too low (you need one and a half or even double the 90V voltage).
