ronsimpson
- Joined Oct 7, 2019
- 4,878
We are off on why simulation does not work. A simple model for an inductor does not include resistance of the wire, capacitance between the layers of wire and most importantly does not include saturation. The Cap in the circuit in post #1 needs to have internal series resistance and inductance. People often use "Perfect" inductors and capacitors and voltage sources and more, then do not know why real parts are not like that. In SPICE putting 200V on a 100V transistor work just fine. I am working with 300mhz transistors that handle 100A. I model the trace inductance in the PCB and in some cases also the trace to ground plane capacitance. SPICE has problems, but most of the time it is because we do not understand the entire circuit. There is a lot more to a circuit then the schematic.
I am using a 50 watt resistor that has 12nH of inductance and 35pF of capacitance that are not included in the schematic. At the speed I am running that makes a difference.
