help with (T428 BN7B11) component
engwas
Joined Jan 9, 2009
18
Hi
I have electronic component and did know what is it, it a 3 pin with this (T428 BN7B11) write on it, it found in Inverter 12 to 220v and I search in internet but did not found any thing useful pleasse any one help
thanks
bertus
Joined Apr 5, 2008
22,922
Can you make a scharp photo of the component ?
That also shows the shape and an idea of its size.
Greetings,
engwas
Joined Jan 9, 2009
18
Hello
It read short in all pins and i must replace it and it make fuse damaged so i need to know what is it to buy a new one one
mik3
Joined Feb 4, 2008
4,843
I have read that you found it in an inverter so I think it is a MOSFET used for switching. They use special thyristors (called GTO's-gate turn off) for switching too but MOS are more usual. Take a photo of the inverter to see where the device was connected. Also, try to see what othe devices were connected to it.
mik3
Joined Feb 4, 2008
4,843
Can you identify the control part (controls the device you took out) of the circuit?
If yes, what is it?
Are there any resistors from the output of the controller to the broken device? What value?
mik3
Joined Feb 4, 2008
4,843
From the part number we can't get anything useful. To find what it is you have to see the connections around it and so on.
