Help with bench power supply circuit
ericgibbs
Joined Jan 29, 2010
21,562
I don’t have one as that’s not the schematic I worked too......
It does not matter which circuit you are working too, add a test load of say 47R, 1Watt , for a Vout set of +5V, that's ~100mA.
As 'dendad' points out use the correct resistor setting ratios/values.
If you don't have a 47R at 1W, use two 100R's in parallel.
NOTE: keep checking the temperature of the LM317 as you increase Vout above 5V and do not cook the 47R!
Mike Baker
Joined Aug 31, 2017
148
Yeah i did input that and saw the 65v. Im not being ungrateful, just cant get my head around it... think i need some training!
ericgibbs
Joined Jan 29, 2010
21,562
hi,
On the Plot the left hand scale is the voltage output, each of the 6 horizontal represent the Vout for that value of Resistance I have added.
ie: Setting the POT to O ohms gives ~1.5Vout, 500R gives ~8Vout and so on in 500R steps upto 2k5, which gives a Vout of ~30.5V
The 1k Load will have a Iout [current] of Vout/1k, eg: 8Vout/1k = 8mA,, 30v/1k= 30mA.
You must ensure that the PSU has a minimal load current of approx 10mA to ensure that LM317 can regulate the Vout.
ericgibbs
Joined Jan 29, 2010
21,562
hi,
That pot has Logarithmic change in resistance value, used on Volume controls, its not suitable.
You want a Linear resistance change pot.
I would keep a 1k connected as a load while you are testing.
E
ericgibbs
Joined Jan 29, 2010
21,562
Yes, that will give you the Vout range that you have mentioned, ie: 1.5V thru 24v.
IMO D1 and C3 are not required, add a 1K on the Vout output.
You must ensure that you do not exceed the heat dissipation rating of the LM317 over that Vout range.
eg: say you set for 5Vout at say 0.5A, that would mean that across the LM317 you would be dropping about (32v-5v)= 27V at 0.5A , that's a 13.5Watts!!!!
