Help with bench power supply circuit
ericgibbs
Joined Jan 29, 2010
21,584
There are some biggish items, boxing them up would be a pain,
If you and a friend would like to come and pick out the stuff that interests you, that could be arranged.
dendad
Joined Feb 20, 2016
4,641
That transformer looks a bit small.
there are a few good supplies readily available. You do need to figure out your power requirements.
A good supply can be made from a PC supply. Google will help.
eBay have some interesting regulators. I recently have got one of these...
http://www.ebay.com.au/itm/Numerica...366666&hash=item44070b1126:g:eLcAAOSwIhxZYDQi
But have not set it up as yet.
For high current, a switch mode supply is better as the losses are less.
It is handy to have a number of supplies at set volts, as well as a variable one.
http://www.ebay.com.au/itm/Variable...402741?hash=item41c5ccb9f5:g:6CQAAOSwAPVZJSo9
One like this will be good.
Mike Baker
Joined Aug 31, 2017
148
ive found a 32v 1.5a power supply lying around, can i use it with the existing componants??
Im mostly only going to be using it between 6 - 12v in reality.
dendad
Joined Feb 20, 2016
4,641
That sounds like it could be a HP printer supply.
So you have 48Watts to play with.
If you use a switch mode regulator with enough i/p volts rating that would be a good supply to use.
have a hunt on Ebay. There are lots there, and just make sure the regulator can take the input volts.
http://www.ebay.com.au/itm/DC-DC-Bu...413983&hash=item41cc4b6108:g:KlUAAOSwKzpZhunC
This one will let you get about 2Amps at 24V.
Limiting the output to 12V, you could get about 4Amps from that 32V supply with a suitable switchmode regulator.
dendad
Joined Feb 20, 2016
4,641
Yes it is a HP power supply! Ill give it a go then.
Just make sure the reg you use can handle the 32V input, preferably higher! And if you go with an analog one, like the LM317, you will run into a lot of heating problems, mainly with higher current and low output voltage,
dendad
Joined Feb 20, 2016
4,641
Yep :)
That will be a good starting supply. many people have used the LM317 like that.
You could add one of these...
http://www.ebay.com.au/itm/DC-3-30V...hash=item25d66747ba:m:m0NjocAYqCpkThN9z_0lfBA
There is also one with volts and amps available there somewhere.
Do you have a multimeter? If not, these are EXCELLENT!!
http://www.ebay.com.au/itm/AN8008-T...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
A good multimeter is a must to help you develop electronics.
And this too.
http://www.ebay.com.au/itm/M328-LCD...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
tHIS http://www.minute-man.com/acatalog/Multi_Voltage_Economical_Power_Supply.html is pretty cheap and cool for a power supply, It is basically an LM337 with fixed voltages and a multi-tapped secondary, so it keeps the power dissipation down. I'm not saying it's the greatest thing in the word, but it's linear quiet supply. It's found on ebay too.
You could still build your regulator and get better control of your varied voltages, but you might not need it.
Right now, 3.3V, 5V, 12 V and 24V are common fixed single supplies.
Mike Baker
Joined Aug 31, 2017
148
i would like to add a constant 12v supply from this circuit as well as the variable, it will be to power a heatsink fan. How would i do this please?
I will be using the 32v 1.5A HP power supply for this.
dendad
Joined Feb 20, 2016
4,641
A switching regulator is quite ok for a fan. And running a 12V fan, not mains, makes sense. No mains wiring needed and that is a good thing.
I'd go as far as to add a couple of those switching regs, and have a 5V USB power socket as well as a banana plug post to the 5V.
And a preset 12V for the fan with another banana plug post.
And finally, have the variable output terminal.
