Help with bench power supply circuit
Mike Baker
Joined Aug 31, 2017
148
I have a 240v ac - 22v dc plug in transformer lying about.
If i used it in place of the transformer and bridge rectifier would the circuit still work?
(i know i will only be able to get a max of 22v and not 24v)
recklessrog
Joined May 23, 2013
985
The photo shows that it can accept 100-240 Volts input which makes it most likely to be a switched mode supply without the mains isolating transformer shown in your schematic. These can be problematic due to some not having the output fully isolated from the input.
Check for any resistance (continuity) reading between the plug pins and the output connector.
ericgibbs
Joined Jan 29, 2010
21,583
OK, so the bridge rectifier in your original circuit is not required.
EDIT:
I would say the two 1000uF caps is an overkill for a nominal 800mA
Use just one.
ericgibbs
Joined Jan 29, 2010
21,583
I would say for bread board projects, 800mA would be OK.
If you are considering driving motors etc, you may need 2 to 5 amps.
What are the projects.?
ArakelTheDragon
Joined Nov 18, 2016
1,366
Over the gretz bridge rectifier you have "1.2V" dropout, so after it you have "22.8V" plus the transformer is not perfect it might be "23V" not "24V", so "22V" is ok if its an AC to DC adapter. But I dont know if its good for prolong use. Normally a transfomer has to be picked properly, because if it heats up it will break. As for the projects, depends what you are doing. "800mA" can be enough but you have to calculate it for your project.
ericgibbs
Joined Jan 29, 2010
21,583
That would be OK, but you must consider the LM317's current and heat dissipation limitations,
EDIT:
You will find as you build more complex projects you will require more than one PSU.
