Need help picking a bench power supply.
Austin Jasss
Joined Jul 13, 2017
5
I'm for looking for a DC variable power supply.
  1. How much you're willing to spend- up to $100
  2. Minimum and maximum voltage - 0-30v
  3. Minimum and maximum current 0-10A
dendad
Joined Feb 20, 2016
4,641
I have used one of those for a couple of years and find it quite ok. That is, after it failed soon after I got it and the fault was the relay that switches between ranges. It has otherwise been very reliable and is in use almost every day.
So I would say, Yes. Get one of those.
And for the times you need higher currents, build a fixed supply or use a modified PC supply.
