Help me understand MIC impedance and gain (Microphone)
28,527
Without adding electronics, it would just be connecting the pickup coil between Tip and Ring, and the shield tied to Sleeve.
I will need to dig in my archives to find a phantom powered amplifier circuit. Unfortunately the majority of published phantom powered microphone amplifiers are for electret mic cartridges. I know that some dynamic mics have amplifiers internally but I don't recall seeing that circuit type published. What could work is to take the PCB out of a dynamic mic that has some damage. OR maybe a microphone company would sell the PCB. If it works for a magnetic mic it should work for a coil type pickup.
Audioguru again
Joined Oct 21, 2019
6,826
Post #17 says that the mic is an internal condenser mic powered from 5V to 9V but of course it is a condenser electret mic with a Jfet impedance converter that is powered from the low DC voltage. The acoustic guitar is hollow and does not have a magnetic electric guitar pickup.
28,527
Certainly correct, AG, I was thinking about MY Stratocaster guitar. So a circuit for en electret mic IS what the TS requires. If the present amplifier does not draw more than 7 or 10 milliamps then a phantom power connection should work, except for needing to drive the two sides of the circuit out of phase and with similar source impedance.
Audioguru again
Joined Oct 21, 2019
6,826
I have never looked at the phantom powering and balancIng circuit inside a PRO microphone. I have an Audio-Technica mic that has those features and I simply plug its XLR connector into a mic preamp/mixer and use it.
28,527
The beauty of Phantom Power is just that: Plug in the microphone and the power is connected!
There are circuits available for download in the "Schematics for free"website, about 4 menu levels in. But all you get is the circuit with the parts identified.
Probably other electret mic circuits are available somewhere else as well.
