Help identifying screws
popcalent
Joined Mar 17, 2018
138
Hi, all.
I need help identifying these screws and the screw driver I'd need for them. This is an old power supply from an external floppy disk drive. Thanks!
KeithWalker
Joined Jul 10, 2017
3,613
That is a Torx security screw. They require a special screwdriver but can be sometimes removed by breaking off the center pin with a small flat screwdriver. Then they can be removed using a standard Torx wrench. If that doesn't work, try a small, flat screwdriver that just fits into the head beside the center pin. I have used both methods successfully.
popcalent
Joined Mar 17, 2018
138
I received the screwdriver. It was a T20. I was able to unscrew the panel only to find out that inside there are some Phillips screws with the same dot in the middle. Screw it, I'm using a Dremel!
