Heat sink for 20 amp cylindrical diode?
MisterBill2
Joined Jan 23, 2018
28,294
Probably the original application was in an automotive alternator embedded into a massive heat sink and with perhaps 50 CFM of airflow constantly.
30,810
Yeah, you might want to think about devices that are capable and built to be designed for heat-sink mounting, such as the alternator variety mentioned.
e.g. pressed-in versions.
Saluki
Joined Feb 23, 2019
80
Could be. I've not compared spec sheets from several different mfgrs. for this part number. There are even Schottky versions, which seems weird -- I thought the "10" in the part number referenced the 1000v Piv, and that Schottky "20A10" I saw a datasheet for yesterday had a PIV of (somewhat expected for its type) 70v. :rolleyes:
Saluki
Joined Feb 23, 2019
80
Yeah, that's the fallback plan. I also have a 200 amp diode out in the shop somewhere. Not sure of the voltage rating but IIRC it came out of a 480v 3-phase device. It'd be it's own heatsink, but it's not gonna fit in a "handi-box"!
Saluki
Joined Feb 23, 2019
80
Update: Well, I couldn't find my little bottle of flux for Aluminum and Aluminum to Copper, etc. Rats! But, it has been 15+ years since I'd used it... So... I went looking for soft Copper I can "coppersmith" with. Heh, this should last me the rest of my life: https://www.menards.com/main/plumbi...il-tubing/22100076/p-1444436527694-c-8565.htm
They have an 11% rebate going too... :)
Dehv
Joined Dec 19, 2021
2
I doubt very much that the manufacturers ever use a diode in a space heater.
I just looked inside one, and the low/high switch is either direct or through a shrink wrapped bulge (diode)? on half power. Next time I take it apart I guess I will test if it's a diode. Not sure what else it could be?
MisterBill2
Joined Jan 23, 2018
28,294
I am amazed! Usually the high/lo selection would go to a tap on the heating coil. The lump will be a diode, I am sure. It must be cheaper to do it that way now.
